Hi, I was curious as to what I can do to fix my surface finish issues. I am engraving some text, following the outline of the letters with a 90* .375" drill point end mill. I am cutting a .050" deep. What I am noticing is that the groves I am cutting, the surface finish is far better on the conventional side and worse on the climb side. I end up with a much rougher finish. I am cutting 6061 t651 and am just manually spraying some cutting fluid using a CNC knee mill.
Is it a speeds and feed issue? I tried varying speeds and feeds, but with similar results. Chip recutting in the trough on the climb side? Looking for any and all ideas on things to do to fix my surface finish.
Thanks much
Brian
