Okay... I think I'm missing a jumper, or a Mach3 setting, or something...
I have everything wired in per Keling's schematic. Took a little tweaking in Mach3 to get the motors turning, but they finally fired up!
However... The motors have such little torque that I can STOP them with my index finger and thumb! They are the 520 oz smooth steppers with the KL5056 Digital Drivers.
I'm running the KL600 48v. Power Supply, and here's my question...
The positive wire from the power supply is "daisy chained" across three of the digital controllers. Would this be "splitting" the required voltage causing low torque in my motors or do I simply need to mess with the kernel speed or steps/per?
My G0704 Mill is running stock screws with 10 TPI, so my estimated rate in Mach3 is around 16000!!!?
