587,177 active members*
3,342 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Newbie to OKUMA - ATC problem
    Jun 2010
    We just got our "new" (second hand) OKUMA MA40-HA. So far we have no experience with OKUMA.
    Everything seems ok until we start to try tool change. the machine arrived with tools in it but these are not ours. We would like to take all the tools out of the machine and then to load our tools.
    With our operator trying to learn, i think now there is a difference between the tools data in the machine and the "reality" and so the ATC is stuck.
    In the "ATC operation" screen, the status is "blank" and no more "ready" or "running". Sequence number = 16 - Next tool = 35 - acitve tool = 0 (no tool in the spindle). I think a reset was push during atc operation....
    How can we solve this problem and have the tools out of the machine and then start working with it ?
    Thanks for your help
    Mar 2009
    1982
    Manual mode. Press step forward (or step back) button simultaneously with interlock button (when necessary only) on ATC panel. Maybe You need to select ATC if there is APC on the machine.
    Generally saying, tolls set it very simple on Okuma. You do exactly as is written in manual and that's it.
    NOTE: be careful using "interlock release" button together with step forward/ back. Make sure machine units are in proper state. Spindle tool unclamped, when needed, spindle indexed ...
    Jun 2010
    OK thanks. I already tried this without success.
    I manage to empty tool pots and to empty related pots in the NC tools settings. I move forward.. :-)
    Unfortunately, I don't manage to put back tool folowing the procedure you mention here. The spindle in constantly clamped and I don't manage to manually put tool in it.
    In "diagnose" I have :
    => 15605 spindle tool clamp is is not off
    => ATC change not completed.... (in don't remember the rest)
    As I understand, the ATC is not in right position as I made a wrong manipulation in prior state.
    thanks to help
    Jan 2008
    575
    Quote Originally Posted by thomasunique View Post
    Did the arm move at all when you tried "One step forward"? If it did then you'll have to jog it back to the original poition, load a tool then move on.
    If not Just press "tool unclamp" and hold the release button until it unclamps, load a tool and move on. Without the M codes you NEED a tool in the spindle.
    thanks to help
    This is what I was asking about, did the arm move?
    The beaten path, is exclusively for beaten men.
    Dec 2008
    3122
    We have an MX40-HA,
    The reset button does not re-clamp the spindle, if you remove a tool from the spindle , you must manually reclamp AND delete the tool reference of that tool as it won't toolchange a phantom tool
    ie T1 is removed from the spindle manuallyand re-clamp, MDI in another tool and it will hang as there is no tool to put away,
    same senario in the carousel as there is a pull-stud detector on the incomming tool ---no pull-stud== no toolchange
    BTW, another problem many overlook is the rapid knob turned to zero will give the appearance of a toolchange hangup
    many would pull all the tools, re-load new tools into the carousel noting which tool# goes into what pot#, then update the tool data page
  1. Okuma problem.
    By lisek27 in forum Okuma
    Last Post: 04-13-2016, 05:34 AM
  2. Okuma LAP problem
    By SRT Mike in forum Okuma
    Last Post: 04-16-2010, 01:52 AM
  3. Okuma lathe M0 problem
    By pp-TG in forum Okuma
    Last Post: 03-18-2008, 09:51 PM
  4. Okuma Newbie Needs Help
    By craven12 in forum Okuma
    Last Post: 02-05-2008, 11:15 PM
  5. okuma LB-15 taping problem
    By mikul in forum DNC Problems and Solutions
    Last Post: 02-14-2007, 09:33 AM
