587,872 active members*
3,333 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 - next round of upgrades
    Aug 2011
    57
    ...just can't leave well enough alone!
    Next round of upgrades will be massive so I'm laying it all out before jumping in.
    Here a list of items I'm upgrading to:
    1. Direct belt drive
    2. 1.5hp AC motor w/VFD
    3. Pneumatic drawbar release
    4. Counterbalance system
    They all reside in generally the same area so I'm attacking it all at once. Here are some preliminary layout pics...
    Attachment 316600
    Attachment 316602
    I can pursue it in logical stages like doing the belt drive and AC motor in one stage and then follow up with the PDB and finally the counterbalance.
    -Mike
    Aug 2011
    57
    Re: G0704 - next round of upgrades
    Anyone have an opinion on V-belt vs PolyRib (automotive serpentine style) belt?
    Attachment 317510Attachment 317512
    I'm going back and forth between a 3L v-belt and 4-rib J-section belt for my spindle drive. Both will fit, both are readily available.
    Thanks.
    Mike
    Mar 2016
    19
    i just picked up this motor for 50$ (sent offer), not sure if it interests u
    WEG HP02PB56C 1 5 HP Motor New | eBay
    Aug 2011
    57
    I think I'm going to go the 1000:1 inverter duty route on my build. I plan on only having one set of pulleys at 2:1 so I can under/overdrive the VFD and motor to get my full spectrum of speed and torque.
    -Mike
    Mar 2016
    19
    Quote Originally Posted by MikeSherman View Post
    -Mike
    have any in mind? whats ur target max rpm?
    Aug 2011
    57
    I'm basically following Icvette's trial by fire wisdom and suggestions here:
    http://www.cnczone.com/forums/bencht...formation.html
    The motor is 1725rpm x 2 (pulley ratio) = 3450rpm. Overdrive the VFD by 2x brings it theoretically up to 6900rpm.
    Mike
  1. G0704 milling pockets out of round? Help please
    By abond13 in forum Benchtop Machines
    Last Post: 05-06-2015, 01:35 AM
  2. G0704 Upgrades
    By DRock in forum Benchtop Machines
    Last Post: 05-17-2012, 08:07 PM
  3. Replies: 5
    Last Post: 04-16-2012, 09:25 AM
  4. 2D Contour on a round OD not very round :(
    By kojack in forum Mastercam
    Last Post: 08-11-2008, 01:07 AM
  5. Bob-art and other upgrades.
    By Scott V in forum BobCad-Cam
    Last Post: 02-18-2005, 10:15 PM
