587,250 active members*
3,518 visitors online*
Results 1 to 8 of 8
    Apr 2004
    Torch Height Control
    Does anyone have a set of plans for making a THC ? I have a Hypertherm 1000. Thanks Rxe
    I have the electronics that Rutex sold as a stand alone THC. It worked quite well. I upgraded my table to use his r510a plasma control board which has a thc included in the circutry and no longer require it. I have 2 control boards (1 new and unused for a backup), the set of switches and 1 board installed in a cheap steel case. If you are interested, please email me at [email protected].
    D. Paulson
    5
    THC electronics
    you can go to www.campbelldesings.com
    and find a Torch Height Contorl
    Jim
    Sep 2008
    8
    Could you please send me more info on THC? Thanks Manny
    Feb 2007
    Could you please send me more info on THC? my email is [email protected]
    Nov 2007
    250
    Quote Originally Posted by dpaulson View Post
    Hello, you wouldn't happen to still have any parts, pieces to the Rutex stuff? Allso, did you by chance take any photos of the THC setup you could share? I'm just having a hard time getting to the next step with this setup. Thanks, Aj. use my e-mail if you like: [email protected]
    Jul 2005
    2415
    For low cost Full Digital Torch Height Controller AND powered, isolated Breakout BOB for proper interface for ALL I/O to MACH3:
    www.CandCNC.com/MP3000-DTHC.htm
    Even cheaper is to buy the modular card set with the optional DTHC module and install in your case/enclosure: www.CandCNC.com/UBOB.htm [UBOB Builders Pak II]
    You will need to address the interface to the PC and MACH3 (motion control software) regardless of the type THC you buy/build. In the MP3000 series it's all integrated in. It's the only solution that supports all of the required inputs/outputs needed for machine operation from ONE PARALLEL PORT. Upgrade to Digital Torch Height is a plug-in module and custom MACH Screens and software drivers.
    TOM CAUDLE
    www.CandCNC.com
    Totally Modular CNC Electronics.
    Nov 2007
    250
    Really, the Rutex THC is just that. It's a stand alone type cpu board that is totally independant to Mach 3 control. You can start and stop in manually by buttons or you can do it by mach 3. My machine is set up with it and runs fine. It does lack a few bells an whistles that other THC controls have.
    Go to my website if you care to take a look and download photos and information.
    http://www.awningandsheetmetalbr.com...ne%20build.htm
    http://www.awningandsheetmetalbr.com...nc%20index.htm
    E-mail direct: [email protected] or just reply to thread.
    AJ
  1. G-Code to DXF
    By WayneHill in forum OpenSource Software
    Last Post: 05-19-2021, 11:26 PM
  2. Plasma Torch Height Control System
    By kanankeban in forum Waterjet General Topics
    Last Post: 03-13-2009, 08:55 AM
  3. What to buy from rutex to get going........
    By Apples in forum Rutex Products
    Last Post: 03-01-2006, 05:05 PM
  4. Plasma Torch Height Control System
    Last Post: 11-05-2004, 02:18 AM
  5. How important is torch height control?
    By mm0015 in forum Waterjet General Topics
    Last Post: 08-06-2004, 05:19 PM
