587,482 active members*
3,630 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > Limit and EStop Switches with HCNCPro board
    Apr 2007
    40
    Just trying to figure out which way to go with controller boards and motors. I am looking at the Hobby CNCPro 3-axis Package. But one question is bothering me.
    How does one allow for stop and limit switches when using the Hobby CNCPro board, with no breakout board using Mach3?
    Dec 2006
    118
    Quote Originally Posted by dshowalt View Post
    The pins used for switch inputs to the PC are just routed to solder pads on the controller board. All you really need to do is wire those pads with pull-up resistors, then wire to your switches, and back to ground. +5V is available on the board for the pull-ups.
    Gary
    Apr 2007
    40
    If I understand, wire the pads to the +5v through the Pull up resister to force the pin to go High, then when the switch closes it will pull the pin to ground?
  1. Replies: 33
    Last Post: 02-24-2010, 10:39 PM
  2. Estop & Limit Switch Setup?
    By Regnar in forum Xylotex
    Last Post: 01-06-2009, 09:31 PM
  3. Help with limit switches and Xylotex board
    By dowling177 in forum Xylotex
    Last Post: 11-26-2008, 09:51 PM
  4. HCNCPRO board good for these steppers?
    By mind_nl in forum Hobbycnc (Products)
    Last Post: 03-31-2007, 10:31 PM
  5. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
