587,874 active members*
3,561 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > gun plate need help :(
Results 1 to 7 of 7
    Jul 2009
    99
    can any one help me dra that thing..... i am tired of trying all programs...
    autocad cambam sketchup artcam.......
    what i need is to cut and engrave that little plastic cover on my airsoft gun....
    i traced it on a paper then scanned it and traced it in autocad.....
    but it has a curve in it....
    Attachment 247044
    anyone care to help....
    step by step???
    plz ??
    thx
    Aug 2014
    889
    Re: gun plate need help :(
    I don't have Autocad or SketchUp etc.... but this is how I do it in Inventor. This will work in other CAD systems as well.
    Step 1 Create a sketch
    Step 2 Select the sketch you wish to Revolve.
    Step 3 Revolve
    Step 4 accept and voila a solid Dome.
    Attachment 247058 Attachment 247060 Attachment 247062 Attachment 247064
    I hope this helps. Remember to dimension your sketch lines and arc to your desired size before revolving to a solid.
    Aug 2014
    889
    To be honest, it is hard to visualize what you are trying to do.
    Hard to tell what "gun plate" means what to you. The Gun butt or"stock"?
    Here is another example of extruding and cutting in Inventor. This shape is more like a wing.
    Step1 Create sketch
    Step2 Extrude with a taper
    Step3 Create a work plane above the part
    Step4 Create a sketch on the work plane
    Step5 Extrude Cut the shape
    Step6 the Results.
    Attachment 247068
    Attachment 247070Attachment 247072Attachment 247074Attachment 247076Attachment 247078
    Now, that being said, all CAD software come with detailed how to's to get you started. If not, do a search online.
    Aug 2014
    889
    Elektryk, once you have a Solid model, you can import it in CamBam or ArtCam. From there you can select features of your part and create tool paths etc... and then create NC code (G-Code), that you can then send to Mach3 to machine the part.
    Sounds complicated? It can be.
    Aug 2014
    21
    Quote Originally Posted by G59 View Post
    Step1 Create sketch
    Step6 the Results.
    Attachment 247068
    It's a grip for a handgun.
    I found some youtube videos and a couple websites that are helpful. Do a search on YT, it should bring up plenty of videos for you.
    Jul 2009
    99
    i finally managed to get it done in sketchup....
    i got one done but i cant seem to do the other side
    Attachment 247326
    Attachment 247328
    Attachment 247330
    Aug 2014
    889
    Good for you Elektrik, I knew with some patience and reading you'd figure it out. Can't really see your attachments, as it takes you to a Page Not Found
  1. Surfacing aluminum plate, for tooling plate
    By 30dayo in forum Material Machining Solutions
    Last Post: 12-21-2013, 11:29 PM
  2. Tool Plate / Sub Plate for IH table?
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 02-20-2011, 05:53 PM
  3. Any tips for designing a fixture plate / tooling plate?
    By thackman in forum Benchtop Machines
    Last Post: 12-19-2008, 06:26 PM
  4. Aluminum: flat, bar, sheet, plate, tooling plate??????????
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 06:48 AM
  5. Tooling plate or sub-plate
    By drill in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-02-2006, 09:17 PM
