587,118 active members*
2,730 visitors online*
    Jul 2007
    78
    Cutting Stained Glass
    Has anyone tried vector scoring stained glass on the laser instead of using the usual hand cutting wheel? I tried it and it did work for straight lines and gentle curves, but for a more drastic curve it will break randomly. I was using speed 25, power 100, Frequency 5000 at 600 dpi on my 45 watt. Even tapping after scoring didn't work.
    Nov 2006
    Quote Originally Posted by bisjoe View Post
    To cut tight curves using hand cutter you must not make only one cut at desired cutting line, you have to make multiple circular cuts which are "straighter" (not too tight, pieces shaped as crescent moon). Its like taking small bites. After each cut you break away piece of glass with pliers until you reach your desired cutting line.
    Maybe this aproach will work with laser. Make multiple scoring lines in glass, and break away little by little.
    Pino
    May 2008
    Cutting glass with CNC machine, which is better?
    Scoring by laser or scoring by tool ?
    Scoring with a tool is better than scoring with a laser for glass.
    The tool produces a 'V' shaped break line whereas the laser produces a 'U' shaped break line.
    There are other differences but I have tried both methods and for me the tool wins hands down.
    Tweakie.
    CNC is only limited by our imagination.
  1. Need Help Cutting Glass!!!
    By ariel 1 in forum Glass, Plastic and Stone
    Last Post: 04-06-2017, 07:04 PM
  2. glass cutting table
    By cristian gabor in forum Mechanical Calculations/Engineering Design
    Last Post: 05-29-2009, 07:51 AM
  3. Laser Cutting Glass
    By boxxer_boy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2007, 03:05 AM
  4. Cutting glass
    By SRT Mike in forum MetalWork Discussion
    Last Post: 05-16-2007, 05:13 AM
  5. Glass cutting
    By gabi68 in forum DIY CNC Router Table Machines
    Last Post: 11-12-2006, 03:34 AM
