587,700 active members*
3,485 visitors online*
    Apr 2007
    151
    Lathe Tool Turret
    Having retro fitted an old Deford Orac lathe I would like to complete the project with a tool turret/changer. Denford made such items, but from looking at some blogs they are difficult to control via Mach.
    It then occerred to me that a tool turret is the same as a rotary table, so I am thinking of using a small 4" rotary table powerd by stepper motor set in vertical position on the cross slide, so both centre's match. Then fitting an adapter plate to take turning tools and chucks for centre dills etc, and easly controled as third axsis.
    Has anyone been down this route, or has any experiance with turrets on small lathes? or can offer some advice
    Mike
    Mar 2004
    1306
    A rotary table typically has backlash. You need some way to lock and unlock the table. If you can sort out locking and unlocking, then you can easily sort out the indexing.
    Mark
    Mar 2007
    32
    Lathe turrets typically use hirth couplings to index and lock the tool in position. They are basically two interlocking face gears. There is a lot of torque on a turret when a tool is in a heavy cut. You have to have something that will be able to withstand this torque and not move at all. If you can find a rotary table with a hirth coupling, it might work.
  1. Converting my Engine Lathe to an 8-Station Turret Lathe!
    By widgitmaster in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2018, 04:56 PM
  2. Tool holders for Daewoo lathe turret?
    By Chuck Reamer in forum CNC Tooling
    Last Post: 01-01-2008, 01:14 PM
  3. Dorian JUNKDEX tool turret
    By Farmers Machine in forum Milltronics
    Last Post: 10-18-2007, 08:41 PM
  4. Reversing turret tool position
    By motter71 in forum G-Code Programing
    Last Post: 09-26-2007, 02:57 AM
  5. Tool Turret Index Failure
    By hatchmar in forum DNC Problems and Solutions
    Last Post: 06-10-2005, 12:36 AM
