587,610 active members*
3,504 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Centroid CNC Control Products > CNC11- Any way to put up Graphic when part cutting?
    Sep 2013
    326
    Is there a way in the CNC11 3.1x Mill setup w/ DCAIO to run a program and also put up the F8 graph of the mill job while cutting? Similar to Mach3? I do miss the feature. Wondered if there is a way possibly? TIA
    JJ
    Feb 2008
    280
    Re: CNC11- Any way to put up Graphic when part cutting?
    It is called "Run-Time Graphics", or "RTG". Turn it on and off using the F10 key on the F4/Run options menu.
    By default, you need to turn it on using the menu option.
    If you want it to default to being on all the time, set Machine Parameter 150 = 1.
    As long as Run-Time Graphics is turned on when you start the job, then you can switch back and forth between the G code display and the Graph display, as the job runs, using the F8 key.
  1. Upgrade from CNC7 to CNC11 worthwhile?
    By JLeather in forum Centroid CNC Control Products
    Last Post: 02-28-2015, 07:51 AM
  2. Ajax CNC11 with 4th axis
    By dougputt in forum Centroid CNC Control Products
    Last Post: 01-07-2015, 01:25 AM
  3. Cutting a 3d part
    By wwwmthboardscom in forum Uncategorised CAD Discussion
    Last Post: 03-09-2011, 11:17 PM
  4. Machining my part with out cutting everything
    By desktoprouters in forum Solidworks
    Last Post: 02-14-2007, 09:06 PM
  5. Cutting a part out
    By MagTDK in forum MadCAM
    Last Post: 10-13-2006, 05:31 PM
