587,155 active members*
4,628 visitors online*
IndustryArena Forum > MetalWorking Machines > Smithy > Autocad to Smithy EMC2? Hello earth to Smithy!
    Jan 2012
    14
    So how do you get Autocad converted to EMC2? I am totally lost.
    Mark
    Feb 2007
    711
    you need a CAM program. Something that will take the shape you have made and turn it into a toolpath. Look for Cut2d, i think you can get a demo.
    there are probably hundreds of options, so search around and find what fits you best.
    Jan 2012
    14
    TO MILL 3D....
    Let me explain better sorry. I have EMC2 powering a Talon CNC 1240 Bed Mill and all my designs are done in Autocad .DXF file format.
    Yet the EMC2 software requires .NGC files in order to mill in 3D.
    I would appreciate any advice from anyone who might have a solution for me to be able to Post process .DXF to .NGC?
    Mark
    Feb 2007
    711
    ngc is the file extension that linuxcnc (emc) uses. It is just regular g-code.
    If you have a cam program already, just choose the linear inch (or mm) g-code post processor. tap is the file extension on some. just rename to .ngc, or let linuxcnc look for different extensions.
    is this what you mean? or do you need a recommendation for 3d cam software? I though that autocad was only 2d drafting. do a search for vectric, artcam, dxf2gcode, etc.. you literally have a hundred choices.
    Jun 2007
    3734
    This can read DXF and create the Gcode you need. Just save the Gcode as .ngc
    NCPlot.com - Tools for CNC Programmers
  1. Smithy Projects & Smithy Machines Group
    By nedtron in forum Smithy
    Last Post: 05-10-2008, 04:06 AM
  2. Smithy 516
    By bilinghm in forum Benchtop Machines
    Last Post: 01-31-2008, 09:25 PM
  3. Smithy 3 in 1 ?
    By fyffe555 in forum Smithy
    Last Post: 12-29-2007, 03:26 PM
  4. new used smithy
    By john Lucas in forum Smithy
    Last Post: 11-16-2006, 09:50 AM
  5. Smithy to a CNC?
    By ishamon in forum Linear and Rotary Motion
    Last Post: 11-24-2005, 05:08 AM
