587,480 active members*
3,376 visitors online*
    Mar 2009
    1863
    Post processor for GibbsCam
    Does anyone out there have a post processor for GibbsCam to make programs for the series 2 Tormach?
    I have a Fanuc post now, but it would be nice not to have to edit every post I make.
    May 2004
    4519
    If you have PostHASTE you can generate your own post processor. You need the base text file to start with.
    Mar 2009
    199
    Do you have a Haas post, that should be very close.
    May 2004
    4519
    Check this thread for Gibbs post processors:
    http://www.cnczone.com/forums/gibbsc..._needed-2.html
    Mar 2010
    8
    I only do 2.5D machining with Gibbs and have been using the Centroid M50 (M841.87) post with very good success with my PCNC770. The only change I've had to make was to add an "M25.m1s" macro in the Mach3 (or PCNC) macro folder to perform the same function as an M998. I normally uncheck "prefer macros" in the various machining pallets before running the post so I can't comment on how compatible the macros are with Mach3.
    The Centroid post is available from the link in the previous message above.
    BTW, Thanks for the link txcncman!
    Jun 2021
    6
    Re: Post processor for GibbsCam
    Steve,
    Your inbox was full so this is how I'm getting back to you. Send me your email. It might work, but when I sent it too someone with Powermill it didn't work. But maybe we can work on fixing the .post for Gibbscam to make it work for you using mine.
    Conner
  1. GibbsCAM post processor
    By bbjang in forum Want To Buy...Need help!
    Last Post: 12-25-2014, 05:23 PM
  2. Gibbscam Post processor
    By LEE-APEX in forum Community Club House
    Last Post: 11-13-2013, 11:57 AM
  3. post processor gibbscam for fanuc
    By igig2004 in forum GibbsCAM
    Last Post: 11-03-2010, 12:22 PM
  4. Gibbscam post processor
    By RPS68 in forum Tormach Personal CNC Mill
    Last Post: 06-07-2009, 05:52 AM
  5. gibbscam haas post processor
    By cowboysam777 in forum Haas Mills
    Last Post: 05-27-2008, 10:51 PM
