587,920 active members*
3,411 visitors online*
Results 1 to 18 of 18
    Jan 2009
    7
    FANUC PARITY ERROR
    Hi everyone , i find this forum by looking to solve my lathe problem ,
    The problem is : the machinist change the battery on lathe and they had this message : ram parity error the model is fanuc 10t on a Morei Seiki lathe year 1988. i don t have any book or anything else about the pmc parameter or anything else ! does someone have it for this machine and controller ???
    Thanks a lot ! the production is stopped since last friday !
    What is the model number and serial number?
    Make sure you change the batteries before reloading parameters.
    Jan 2009
    7
    LATHE SERIAL NUMBER IS : #1768 MORI SEIKI SL-25 1989
    CONTROL IS FANUC 10T
    WE SEE ON CONTROL : F10T9B 1260E
    THANKS FOR HELP
    Jan 2009
    7
    I ve got the procedure for re install the NC parameter of my mori seiki lathe, I did it and it work, but i still have an alarm ALM344, " A VALUE AUTHER THAN 8 . 10 OR 12 WAS INPUT TO THE PARAMETER AS A SETTING FOR THE NUMBER OF STATIONS D108 OR D109 "
    I CAN T SEE THE PARAMETER D108 IN MY DATA PAGE !! THE NUMBER OF DATA STOP AT A074 DOES SOMEONE KNOW WHY ???? PLEASE NEED HELP THE TECHNICIEN FROM TORONTO DON T KNOW WHY EITHER !
    You need to load your PC parameters.
    Press the NC/PC pushbutton.
    Then select parameters.
    Then load data table, keep relays, counters, and timers
    Jan 2009
    7
    i did it , i was nt able to change the date table for D0108, but i find how did it , i had to press the "double arrow key" and the "simple arrow key " at the same time to change for D108 so my data parameter are set
    But the problem is , i m still have the S027 z dgtl servo error what have i to do ?
    thansk a lot
    May 2005
    109
    Quote Originally Posted by DIE FAST View Post
    thansk a lot
    You got wrong servo parameter. Try correct it.
    PM your email. I could send you some of 10T parameter.
    Jan 2007
    43
    Mori SL-25 SER# 1767 Parameters Please help!
    I have an SL-25 with a Fanuc 10T control and lost the parameters. I am told I need parameter from someone with a Mori with a close serial # and your is only one digit off. Could you reply to this or even phone me at 306-768-7771
    Thank you in advance!!
    Jun 2008
    1511
    While you are waiting for a reply have you tried calling Mori to see if they have the parameters for you?
    Stevo
    Apr 2009
    24
    When you change batteries on a CNC machine you need to do it powered up. This way the power keeps the settings. The battery is just for power off retention.
    Jan 2007
    43
    Got it running! Can't hardly wait to start puching out widgets!
    Jun 2008
    1511
    Quote Originally Posted by thesaurian View Post
    Wow you got lucky. That is the fastest I have seen someone get there machine running after losing all data and having no backup.
    My suggestion now is to backup EVERYTHING. This is the first thing that should have been done when you put power to the machine. On the 10series fanuc you cannot punch out your PMC data via RS232 so you have to write it all down. Get all of your macro programs out of the control as well.
    Stevo
    Jun 2011
    I need keep relays, counters, and timers data for mori-seiki SL-25Mc
    Apr 2009
    24
    My control is a Yasnac. So I don't think I can help you.
    Jun 2011
    i have the data back up of mori sl-25 but the controller is FS-15
    i dont know PMC parameters for system 15 and 10 are same or not....
    if you want the data then contact me on [email protected]
    Nov 2012
    10
    Fanuc 15-T
    Hi, I'm facing a similar problem on my Mori Seiki SL-25B with Fanuc 15-T.
    I'm getting a ram parity error once i press the power on button, and the CNC software just freezes and gives me IPL options, any help would be appretaied.
    Jan 2013
    19
    PROBLEM WITH MORI SEKI SL25
    Hello there iam having a problem with my Mori Seki Lathe model SL-25m ,Sl no: 200, model :1989...iam trying to make taper thread using the G76 code since it is 10T fanuc control ( single line thread code ) ...But after 3 or 4 threads i keep gettig the F10T9B 1260E ALARM & The machine crashes .....sometimes the whole program runs without any problem....But most of the time i get error......This has caused a lot of problem & the productin has stopped.....PLease help & advise how to fix this your help will be most appreciated ......
    Mar 2022
    5
    I have Okuma & Howa ACT-4 fanuc OTC machine . While switching on machine got alarm of 911 Ram Parity : (High)
    After entering three different alarm shown as follows
    1) 100 P/S Alarm
    2) 417 Servo alarm : X axis DGTL PARAM
    3) 427 Servo alarm : Z axis DGTL PARAM
    I don't have backup of parameters....can anyone guide me on above alarms to correct and make machine run???
  1. fanuc 10T ram parity error
    By jolulank in forum Fanuc
    Last Post: 07-30-2021, 08:39 AM
  2. Fanuc 10 M Ram parity error
    By cncmori in forum Fanuc
    Last Post: 02-17-2020, 01:20 AM
  3. FANUC 16 TT A 912 RAM parity Error
    By bensttech in forum Fanuc
    Last Post: 04-11-2014, 01:16 PM
  4. Fanuc 0-MD low ram parity error
    By samu in forum Fanuc
    Last Post: 06-13-2013, 08:50 PM
  5. Replies: 0
    Last Post: 11-26-2012, 09:03 PM
