587,872 active members*
3,964 visitors online*
Hybrid View
    Dec 2005
    436
    Tool Length offset?
    I am using Mach3.
    The post-processesor Inserts a G49 ( Cancel tool length offset) at the beggining of the G-code.
    I manually change tools
    It seems strange that it gets canceled and is not re-instated (G43)anywhere.
    Can someome tell me how Tool length offset this (G49&G43)is dealt with normally?
    Jun 2007
    61
    g43
    You must give the g43? at m6t? point in your program.As an example with EMC from which Mach is copied with a manual change machine:
    m1 (pause machine)
    m6t6 (1/2 CEM on my machine)
    g43h6 (offset length of 1/2 CEM)
    # (G codes)
    g49 (cancels tool length compensation)
    Jun 2007
    21
    post processors can be set-up to cancel or preset modals. can cycles, cutter comp, abs or inc postioning ect, ect. i personally dont use too many of these features as we are a small shop and we have just a couple foks that get into the programs. if i were in a very large shop i might use the features to preset the machine just so i know my programs will run correctly from the start. you never know what the last guy or his program might have left in the machine as far as modals or cycles that may give you headaches.
    Feb 2007
    246
    My Mach 3 post does the same thing, I just put in a G43 after my tool changes when im editing the right tool number from my setup page.
    Live free or die
  1. Tool length sensing!
    By Swede in forum FlashCut CNC
    Last Post: 05-07-2013, 04:38 AM
  2. G43.1 - Tool Axis Direction Tool Length Compensatioin
    By EngTech in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-06-2007, 11:01 AM
  3. Tool length detection
    By PsyKotyk in forum LinuxCNC (formerly EMC2)
    Last Post: 03-07-2007, 03:47 PM
  4. NC reading tool length from offset page, not data page..?
    By RMagnusson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-21-2006, 11:07 PM
