587,362 active members*
3,487 visitors online*
    Feb 2014
    21
    Problem after install
    I installed the 2010 while following the video on YT, I have everything set up in Mach3 but once I chose the"view" 2010 screen, none of the controls work, no y /x z access movement at all, when I switch back to the Mach3 screen, everything works. I am not sure what I missed or why things aren`t working, but if anyone can guide me I`d appreciate it...
    Thanks R.
    Re: Problem after install
    Did you copy the macros from \Mach3\macros\2010 into \Mach3\macros\yourprofilename\
    Feb 2014
    21
    Hi Ger,Yes I did.
    Feb 2014
    21
    Problem solved, all set now.
  1. UCCNC won't install. Any one have this problem?
    By rlrhett in forum UCCNC Control Software
    Last Post: 11-06-2015, 03:12 PM
  2. SSHD install problem
    By RP Designs in forum Centroid CNC Control Products
    Last Post: 08-02-2009, 06:06 PM
  3. Mill v1.27 problem install
    By MILLMANM in forum Centroid CNC Control Products
    Last Post: 01-10-2006, 12:29 AM
  4. Install Problem
    By crow in forum Uncategorised CAM Discussion
    Last Post: 02-18-2005, 05:43 PM
