587,213 active members*
3,121 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Convert manual Bernardo KF 20 L Super milling ma to CNC, but keep manual mode option.
    Hello,
    I am considering buying a Bernardo KF 20 L Super manual milling machine, and then later buy a concersion kit to make it CNC.
    In the meantime, i like to also use the machine sometimes for smaller manual jobs where i do not want to make the whole setup on computers ect, but just cut some metal quick manually.
    Anyone have modified such a machine to CNC, but where the manual operation with the handles are kept in place?
    P.s Any one have converted this machine into CNC?
    Thank you.
    Martin
    Re: Convert manual Bernardo KF 20 L Super milling ma to CNC, but keep manual mode opt
    It looks like a fairly common Chinese machine with a "Bernardo" badge on it. I don't have one myself so don't know the model names but if you Google you should find a lot of conversions for this same basic machine.
    Jan 2018
    1516
    This one?
    https://www.bernardo-maschinen.com/k...smaschine.html
    SIEG has wide range of SX2L Mini Mill Drill
    Same as the Sieg X2L mini mill (longer table version).
    There's plenty of conversions out there. Personally I don't rate them. I have a Sieg X2 version.
    The table size/weight make it prone to twist and vibrate.
    Y axis distance is lacking.
    MT3 taper. (R8 is far superior).
    It can't handle any remotely slightly heavy cutting. You can't go by any recommendations when it comes to feed/speeds.
    Save another few hundred and get the next size up.
    Something like:
    https://www.amadeal.co.uk/acatalog/A...E.html#SID=421
    I'm plenty happy with mine. Wish I'd gone straight to this and not wasted efford on my X2 in the first place.
    There are so many versions of this with differing spec. You can find good value but you really need to look around.
    Bernardo look like they only have old outdated ones with MT2 tapers for stupid cost. Steer clear imo.
    Jan 2018
    1516
    In addition to my previous post.
    The Bernardo KF20 machine is an older version of the Sieg which has the tilting column. NO NO NO....
    If you do go for this size machine look around for the newer version that has the Solid column update.
    The tilting column is a big flaw.
    This is the type of spec you want if you want a usable machine of this size:
    https://www.arceurotrade.co.uk/Catal...-HiTorque-Mill
  1. semi manual mode
    By jschoch in forum Coding
    Last Post: 09-04-2018, 04:09 PM
  2. Help with manual guide option/button
    By ennis in forum Fanuc
    Last Post: 02-09-2013, 08:58 AM
  3. how to get out of manual guide mode?
    By nabil_elbadri in forum Fanuc
    Last Post: 09-11-2012, 08:49 AM
  4. dro in manual mode...
    By triberman in forum Mach Software (ArtSoft software)
    Last Post: 03-02-2011, 08:24 PM
  5. Spindle Manual Mode
    By Mechamatic in forum Tormach Personal CNC Mill
    Last Post: 09-18-2008, 06:52 PM
