587,405 active members*
3,190 visitors online*
    Oct 2007
    Macro program
    I have a Seicos 18M cotroller. The manual says there is a o9000 program for the M6 to call up for tool change. Is this a Hitachi Seiki specific program, or is it a program I write and upload?
    Roger
    Sep 2007
    33
    Usually the programs in 9000's are all written by the machine builder/installer. Not sure if this applies to your case, but most likely. Sometimes they are also password protected so operators can't change anything in those programs. The manual should tell you all of this.
    Oct 2007
    Thanks for the reply. What is really baffling me is that there are two sets of parameters in this machine. I am searching for the system macro variable that tells me the spindle tool. In most Fanuc based controllers, variable #148 is the number of the spindle tool. Not in this case. I use it in my macro check to make sure the right tool is in the spindle in case of restart in mid-program. Any thoughts?
    Roger
    Sep 2007
    33
    I know how that goes. I still cannot find a parameter that is causing our dress macro program to hang up every once in a while. Hopefully this isn't your scenario. If the parameter isn't listed in Seico's manual, the builder/installer's manual should have it. By spindle tool do you mean the spindle that rotates the tool changer? I am having no luck finding a manual to that control either.
    Oct 2007
    The controller is actually a 10M. I have the manuals. The actual spindle that machines is the one I'm talking about. Variable #149 can be activated by using a "T"code callup in the 6000 parm. This only gives me call up reference. I'll keep looking. I will probably write a program that fits to the controllers limitations.
    Roger
  1. Mazatrol Program into a G Code Program
    By fuzzman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-25-2012, 04:27 PM
  2. Replies: 12
    Last Post: 03-15-2010, 02:19 AM
  3. what is a macro?
    By ljoe1969 in forum Autodesk
    Last Post: 07-12-2006, 02:12 PM
  4. cycle time macro program
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-29-2006, 07:33 PM
  5. Replies: 11
    Last Post: 10-09-2005, 05:45 AM
