587,278 active members*
3,169 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal VMC 40 Questions (1992)
Results 1 to 7 of 7
    Mar 2009
    27
    Hey Guy's ....Me again
    Like I said...It's been a few yrs since running a fadal (17yrs) and I have a couple of questions
    1.) Cold start position on X and Y I got...But I think the bracket for cold start position on Z must be broken or gone or I am not seeing it??? any help finding it so I can get tool change position correct.
    2.) Does anyone know the wiring connection (schamatic) for the rs232 port and what type of DNC parameters is best etc.
    3.) which is better to programming system to use on fadal 1 or 2 or is it just preference. I like it close to Fanuc as possible.
    4.) I'm trying to remember how we use to program this fadal as far as Cold Start position and work offset........ I think we reset (setcs) to a unload part position (middle of table and y all the way forward.) Then at the beginning of the program we used a G92 X Y is so far from Cold Start Position........
    does that sound right or is there a better way to program it
    5.)when your picking up X Y etc. for work offset how do you designate which offset you want to use like G54 G55 G56 or E1 E2 E3 etc.
    example: (setx,1 enter sety,1 enter) or what? cant remember
    6.) I know you are probably saying "Read the frick'n Manual book lazy(nuts)) sorry guy's still waiting on the manuals and I want to get started cutting chips
    Thanks guy's I really appriciate all or any of your help
    TMILLS
    Feb 2008
    547
    Here you go TMILL
    Free down loads of all the manuals.
    http://www.fadalcnc.com/fadal_Tech_Docs1.htm
    Steve:cheers:
    Mar 2009
    27
    Thanks Scadvice-
    I will download those......Very nice!
    But it would still be nice if someone could chime in on the questions needed that the book may not tell me. Like questions 1,3,4
    TMILLS
    Apr 2008
    1577
    3) Format 2 is supposed to be for maximum compatibility with Fanuc controls
    I've got thoughts on some of the other questions but will have to reply later.
    Apr 2008
    1577
    Quote Originally Posted by scadvice View Post
    Steve:cheers:
    WOW! Great resource man, thanks.
    Jul 2008
    21
    Quote Originally Posted by TMILLS View Post
    The "Z" bracket is on the right side on the side of the "Z" ways. Jog up the head and you will see it. It lines up right at the bottom of the head.
    Look in the manual for the cable wiring. I think you use 7,1,1, ( 7 bits, 1 stop bit, 1 parity bit ) but don't remember.
    I only use 1 so I can use the L9XXX subroutines ( pocket, bolt circle, engraving, on and on. )
    After you cold start, move the "Y" to +8. or +10. and sety. Now at the end of the program that is where it stops at. NEVER use setz
    Use the utility's to edge find your offsets UT
    TMILLS
    Hope this helps.
    Mar 2009
    27
    Thanks jbexplorer
    I will try it out!
  1. 1992 Fadal 4020HT startup Z and C axis errors
    By Gerald Sande in forum Fadal
    Last Post: 07-20-2009, 02:54 AM
  2. A few questions regarding fluids in a Fadal
    By Heffner Perform in forum Fadal
    Last Post: 12-17-2008, 09:06 PM
  3. Fadal 4th axis questions
    By carbidecraters in forum Fadal
    Last Post: 02-21-2008, 05:13 AM
  4. Fadal Assist Questions
    By Broda_Machine in forum Fadal
    Last Post: 02-28-2007, 04:09 AM
  5. FADAL control questions
    By SIERRAMACHINE in forum Fadal
    Last Post: 05-02-2006, 03:35 PM
