587,210 active members*
2,850 visitors online*
Results 1 to 9 of 9
    Apr 2007
    151
    Slow Spindle Speed
    My X3 won't reach max speed 3500rpm only 3000rpm, have checked spindle pully in Mach and is set at 3500 max, have tried in manual mode and still slow, so therefore suspect electrics on mill.
    Anyone got any thoughts as to problem.
    Regards
    Mike
    Jun 2007
    3734
    Question Measured how?
    How have you measured the speed? Is it an accurate reading?
    Apr 2007
    151
    Neil
    The readout is at 3000 +/- 100, and I know the sound it is quite distingtive at top speed, I use small cutters so I need top speed
    Mike
    Jun 2007
    3734
    Various models
    There is a maximum speed and minimum speed pot probably on front panel PCB.
    Sometimes on motor PCB assembly.
    I assume you are running on 240v, so the bus voltage near top of motor PCB should be about 330v. Don't zap yourself!
    A few photos of your main PCB and front panel PCB would help identify model.
    TURN OFF POWER before removing front panel assembly.
    One short circuit to the DRO (which is too close to the PCB) and you'll probably kill many components.
    Apr 2007
    151
    Neil
    Front panel won't come of, removed quill lock screw and released cable locks on side of head, and unscrewed readout, but somthing holding panel towards the top!!!!!!
    Mike
    Jun 2007
    3734
    M5 screws.
    There are 2 M5 socket head screws from the top cover -- wrong..
    remove the screw holding the display on (each side of head)
    The wires usually fairly short and need unplugging as you remove the front stuff.
    Apr 2007
    80
    Spindle Calibration Procedure
    Use my calibration procedure detailed here. http://www.cnczone.com/forums/showth...hlight=chrisjh
    Regards
    Chrisjh
    Apr 2007
    151
    Problem solved a turn of the fast speed screw did the trick. although I don't have a tach you can hear motor running faster and DRO reads higher.
    But why did speed ruduce in the first place? vibration maybe!!.
    Out of interest how are your machines doing, given all the glitches the early X3's had, are you tempted with Syil's latest offerings?
    Thanks Neil and Chris for your help.
    Cheers
    Mike
    Jun 2007
    3734
    Crook capacitor?
    Look for leaky small capacitors (electrolytic)
    Replace any near the trim pots.
  1. Servo & slow speed
    By Kencor1 in forum Servo Motors / Drives
    Last Post: 03-06-2009, 03:24 PM
  2. Slow axis speed
    By Aaronem in forum DIY CNC Router Table Machines
    Last Post: 02-11-2009, 12:29 AM
  3. Slow Speed Stalling?
    By bigz1 in forum Stepper Motors / Drives
    Last Post: 04-20-2008, 08:15 PM
  4. Help. Slow speed
    By shamus13 in forum Mach Mill
    Last Post: 12-08-2007, 06:06 PM
  5. Cut speed is stuck at Slow????Mach 2
    By mwalach in forum Mach Mill
    Last Post: 08-24-2006, 12:58 PM
