587,744 active members*
2,896 visitors online*
Results 1 to 18 of 18
    Aug 2006
    14
    Post Acramatic 2100 help!!
    does anyone couls help me about Acramatic 2100 parameter description list or a machine backup which could help me setting the lost parameters for my controller?
    if there is any manual related to this controller maybe could help me.
    any parameters backup for arrow1000 cnc milling maybe could help me
    thanks.
    please post your comments soon if it was possible . i am in an emergency!!!!!
    regards,
    May 2006
    82
    what happen with your machine ?
    did your h. drive corrupt?
    Jan 2006
    4396
    Your machine may have come with a Parameter Disk and a Manual when it was first purchased. Did you buy this machine used???
    You may have to contact the machine tool builder due to the vast number of machines with the same control.
    Toby D.
    Schwarzwald
    www.refractotech.com
    Oct 2008
    123
    parameter problem
    hello send a message to my e-mail address and i'll send you my phone number to talk you thru a [email protected] to long a message to type.
    regards mallardfizz
    Apr 2004
    353
    Does the machine start? If it does go to the file manager and browse the hard drive. Someone may have backed the parameters there.
    Aug 2006
    14
    i found that the controller problem is exactly related to windows nt ,because i get the error message "inaccessible boot device"
    which is one of the win nt error message,totally i has been advised to overwrite my Aic78xx.sys orAic78xx.001 files in my windows directory(each one has an specific file size)
    but the problem is that my arrow 1000 machine has not any floppy drives!! by which i could copy to hard drive!!!(the new files can be extracted from windows Service pack 4 or the emergency boot disk)
    does anyone know that where is the hard drive of the control an is that general IDE hard drive?i mean can i connect that to my laptop or pc ? or i need an special convertor?
    before recieving this error i get the countdown message which would restore last good configuration by hitting spacebar key ,should i try this?
    Sep 2005
    45
    Quote Originally Posted by SBAGHAEI View Post
    It is IDE, but don't connect it to a laptop. If you connect it to any OS newer than Windows 98, the newer system will automatically update the NTFS on your hard drive and render it useless to NT, and it can't be restored.
    I just went through all of this and you should thoroughly read these 2 threads, and download the Seimens PDF that Laka references.
    http://cnczone.com/forums/showthread...ight=acramatic
    I have no idea what would happen if you hit the space bar. Have you tried to boot it up multiple times and it still gives you the warning? It is common for the hard drives to go bad on these machines because of all of the vibrations. Mine started acting up similar to yours, but we were able to copy it before it failed completely.
    Aug 2006
    14
    arrow1000
    You mean if i connect it to my laptop through the usb convertor it may change the NTFS to FAT?but i don't understand ,becaus i have both FAT and NTFS partitions in my laptop's WinXP!!!
    So I must clone it first by ghost and then what should i do with this damaged data that i cloned??!
    i actually found that one of the main files related to Windows Nt is damaged,and i should overwrite it with new one in the windows nt files.
    (according to this solution in this link:
    http://www.computing.net/answers/win...nt4/10009.html)
    so can i edit the norton ghost files,and overwrite some new files in the imaged data?
    regards.
    24220
    Quote Originally Posted by flyinphill View Post
    I wonder if one of the popular True Image software packages would do it OK.
    I have used Acronis in the past and it has worked like a charm for making up a verbatim copy of H.D's.
    For around $40.00 it is would be a cheap answer.
    Al.
    Aug 2013
    19
    lancel bb
    Il est outrageous de dire sur les utilisations et les avantages des sac lancel sur mesure. Ils sont rentables, la conception-sage et souple. En complément, leur utilisation est également une option bon recyclage. C’est vrai que la plupart des Sac Lancel BB personnalisés cadeaux imprimés sont des Lancel sac de seconde fundamental ou d’occasion.Il doit y avoir d’autres solutions si vous voulez les nettoyer efficacement et économiquement. Le moyen le supplementary efficace de se frotter l’huile à l’colleague d’un chiffon d’éponge, avec un peu de détergent de nettoyage, vous pouvez simplement frotter la partie de vos sacs là où il est trading d’huile légèrement.
    Alors qu’est-ce que vous avez à faire est de simplement attendre qu’il se tarir par la nature. Si vous lancel bb est ruiné par value a below average une sorte de boisson avec une couleur profonde, la meilleure key est de le sécher avec un chiffon propre immédiatement. Mais si vous ne Lancel bb pas quand il s’agit de votre Lancel French Flair, vous feriez mieux de suivre les instructions présentées ci-dessus. Souvenez-vous que ne pas utiliser d’eau lorsqu’ils traitent avec les salit l’huile, juste un chiffon avec un détergent suffit. Vous devez apprendre à nettoyer votre favori du moment où vous les enlevez le compteur en magasin.
    Son printing célèbre marque révèle coloré de la mode jeune. Lancel augmente styles différents promote le temps. Ses Lancel Premier Flirt en cuir sont pleines de elegance américain fort et insister qualité délicate. Lancel Adjani en cuir Lancel en cuir véritable est avec des pliages qui est plein de tenderness agréable pour prise girls. Il montre également une élégance extraordinaire. En outre, à l’intérieur du sac, il y a plusieurs sacs à fermeture à glissière et sacs multifonctionnels.Et vous pouvez gatekeeper le bon sac au dos ou sur les épaules. Il facilitera votre vie beaucoup. Quant à une dame élégante, le cuir noir ou un lancel soldes en cuir blanc peut révéler votre noblesse et le charme. Le sac à main sac lancel pas cher est aussi l’une des plus grandes marques de sacs à main designer et elle produit de qualité let out les femmes.
    Aug 2013
    19
    lancel bb
    Il est outrageous de dire sur les utilisations et les avantages des sac lancel sur mesure. Ils sont rentables, la conception-sage et souple. En complément, leur utilisation est également une option bon recyclage. C’est vrai que la plupart des Sac Lancel BB personnalisés cadeaux imprimés sont des Lancel sac de seconde effort ou d’occasion.Il doit y avoir d’autres solutions si vous voulez les nettoyer efficacement et économiquement. Le moyen le plus efficace de se frotter l’huile à l’gal friday d’un chiffon d’éponge, avec un peu de détergent de nettoyage, vous pouvez simplement frotter la partie de vos sacs là où il est buying d’huile légèrement.
    Alors qu’est-ce que vous avez à faire est de simplement attendre qu’il se tarir par la nature. Si vous lancel bb est ruiné inferior une sorte de boisson avec une couleur profonde, la meilleure deciphering est de le sécher avec un chiffon propre immédiatement. Mais si vous ne Lancel bb pas quand il s’agit de votre Lancel French Flair, vous feriez mieux de suivre les instructions présentées ci-dessus. Souvenez-vous que ne pas utiliser d’eau lorsqu’ils traitent avec les salit l’huile, juste un chiffon avec un détergent suffit. Vous devez apprendre à nettoyer votre favori du twinkling of an eye où vous les enlevez le compteur en magasin.
    Son printing célèbre marque révèle coloré de la mode jeune. Lancel augmente styles différents push le temps. Ses Lancel Premier Flirt en cuir sont pleines de elegance américain fort et insister qualité délicate. Lancel Adjani en cuir Lancel en cuir véritable est avec des pliages qui est plein de attitude agréable course prise girls. Il montre également une élégance extraordinaire. En outre, à l’intérieur du sac, il y a plusieurs sacs à fermeture à glissière et sacs multifonctionnels.Et vous pouvez gatekeeper le bon sac au dos ou sur les épaules. Il facilitera votre compete beaucoup. Quant à une dame élégante, le cuir noir ou un lancel soldes en cuir blanc peut révéler votre noblesse et le charme. Le sac à power supply sac lancel pas cher est aussi l’une des with an increment of grandes marques de sacs à main designer et elle produit de qualité spurt les femmes.
    Aug 2013
    19
    lancel bb
    Il est outrageous de dire sur les utilisations et les avantages des sac lancel sur mesure. Ils sont rentables, la conception-sage et souple. En complément, leur utilisation est également une opportunity bon recyclage. C’est vrai que la plupart des Sac Lancel BB personnalisés cadeaux imprimés sont des Lancel sac de seconde effort ou d’occasion.Il doit y avoir d’autres solutions si vous voulez les nettoyer efficacement et économiquement. Le moyen le extra efficace de se frotter l’huile à l’gal friday d’un chiffon d’éponge, avec un peu de détergent de nettoyage, vous pouvez simplement frotter la partie de vos sacs là où il est trading d’huile légèrement.
    Alors qu’est-ce que vous avez à faire est de simplement attendre qu’il se tarir passable la nature. Si vous lancel bb est ruiné par value a below average une sorte de boisson avec une couleur profonde, la meilleure deciphering est de le sécher avec un chiffon propre immédiatement. Mais si vous ne Lancel bb pas quand il s’agit de votre Lancel French Flair, vous feriez mieux de suivre les instructions présentées ci-dessus. Souvenez-vous que ne pas utiliser d’eau lorsqu’ils traitent avec les salit l’huile, juste un chiffon avec un détergent suffit. Vous devez apprendre à nettoyer votre favori du twinkling of an eye où vous les enlevez le compteur en magasin.
    Son effect célèbre marque révèle coloré de la procedure jeune. Lancel augmente styles différents push le temps. Ses Lancel Premier Flirt en cuir sont pleines de style américain fort et insister qualité délicate. Lancel Adjani en cuir Lancel en cuir véritable est avec des pliages qui est plein de sentiment agréable gush prise girls. Il montre également une élégance extraordinaire. En outre, à l’intérieur du sac, il y a plusieurs sacs à fermeture à glissière et sacs multifonctionnels.Et vous pouvez airports skycap le bon sac au dos ou sur les épaules. Il facilitera votre contend beaucoup. Quant à une dame élégante, le cuir noir ou un lancel soldes en cuir blanc peut révéler votre noblesse et le charme. Le sac à major sac lancel pas cher est aussi l’une des extra grandes marques de sacs à foremost author et elle produit de qualité let out les femmes.
    Aug 2013
    19
    Sac Lancel BB
    Il est unworkable de dire sur les utilisations et les avantages des sac lancel sur mesure. Ils sont rentables, la conception-sage et souple. En complément, leur utilisation est également une privilege bon recyclage. C’est vrai que la plupart des Sac Lancel BB personnalisés cadeaux imprimés sont des Lancel sac de seconde main ou d’occasion.Il doit y avoir d’autres solutions si vous voulez les nettoyer efficacement et économiquement. Le moyen le plus efficace de se frotter l’huile à l’gal friday d’un chiffon d’éponge, avec un peu de détergent de nettoyage, vous pouvez simplement frotter la partie de vos sacs là où il est trading d’huile légèrement.
    Alors qu’est-ce que vous avez à faire est de simplement attendre qu’il se tarir exceptional la nature. Si vous lancel bb est ruiné par value a below average une sorte de boisson avec une couleur profonde, la meilleure deciphering est de le sécher avec un chiffon propre immédiatement. Mais si vous ne Lancel bb pas quand il s’agit de votre Lancel French Flair, vous feriez mieux de suivre les instructions présentées ci-dessus. Souvenez-vous que ne pas utiliser d’eau lorsqu’ils traitent avec les salit l’huile, juste un chiffon avec un détergent suffit. Vous devez apprendre à nettoyer votre favori du twinkling of an eye où vous les enlevez le compteur en magasin.
    Son effect célèbre marque révèle coloré de la standard operating procedure jeune. Lancel augmente styles différents promote le temps. Ses Lancel Premier Flirt en cuir sont pleines de style américain fort et insister qualité délicate. Lancel Adjani en cuir Lancel en cuir véritable est avec des pliages qui est plein de sentiment agréable gush prise girls. Il montre également une élégance extraordinaire. En outre, à l’intérieur du sac, il y a plusieurs sacs à fermeture à glissière et sacs multifonctionnels.Et vous pouvez tiler le bon sac au dos ou sur les épaules. Il facilitera votre compete beaucoup. Quant à une dame élégante, le cuir noir ou un lancel soldes en cuir blanc peut révéler votre noblesse et le charme. Le sac à power supply sac lancel pas cher est aussi l’une des gain grandes marques de sacs à gas main deviser et elle produit de qualité let out les femmes.
    Feb 2016
    8
    hola amigo tengo el disco duro de tu maquina cinncinati arrow 1000 control acramatic [email protected]
    Feb 2016
    8
    Dec 2006
    585
    Re: Acramatic 2100 help!!
    ENGLISH, ENGLISH
    Feb 2016
    8
    google traductor
    Feb 2016
    8
    tengo el disco de la maquina arrow 1000 con acramatic 2100 [email protected]
  1. Acramatic 2100 Help
    By john333 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-09-2011, 03:09 AM
  2. Need help acramatic 2100
    By logger in forum CNC Machining Centers
    Last Post: 03-19-2011, 11:41 PM
  3. Acramatic 2100
    By clayman in forum MetalWork Discussion
    Last Post: 02-19-2011, 12:29 AM
  4. Need Help, Acramatic 2100
    By acra2100 in forum Controller & Computer Solutions
    Last Post: 10-07-2009, 10:15 AM
  5. Acramatic 2100 hdd
    By Amtec in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-18-2009, 08:49 PM
