587,877 active members*
5,566 visitors online*
Results 1 to 8 of 8
    Mar 2012
    133
    splash guards/modifacations
    Getting there, I got it enclosed. Sliding door, chips fall into a chip/coolant pan on wheels with drain under stand. The key board, controler, mouse is on and 4 position hindge, 3 angles and down out of the way, plexi glass protector. I also have digital readout, big screen, DVD/VCR. Click image for larger version.
    Jul 2004
    595
    I love your fold down keyboard table with the jog shuttle. That is really trick! I might have to borrow that one. Really good idea.
    David
    Mar 2012
    133
    If you want I can get better pics of it. There is a flat plate under the table on a hinge, with 3 screws for the different heights, when done just lift and it lowers. When running I like it flat. Set up or programing I sit down and like it tipped. The plexi glass is a protector from chips. I made my base because I wanted the chips to fall into the chip and and it is on wheels so I can just roll it out when full. I got a deal on the alum diamond plate $102. Next I need to rig the door to slide open and close automatically.
    Jan 2012
    789
    Wow! Shiny.
    Apr 2008
    24
    That's bad ass! Can I buy a copy from you?? ;-)
    Did you have any problem with splashes on the right side? From the picture I don't see that side being enclosed.
    W.
    Mar 2012
    133
    Yes, you can copy and if need more pics let me know. As for the right side, at this time for most of the parts its ok, later I will get more to cover the right side.
    Dec 2010
    1230
    Very, very, VERY impressive! By far the best I have seen yet.
    Mar 2012
    133
    coolant tank
    I finally got around to the removable chip pan for the coolant tank, just roll out and dumpClick image for larger version.
Name:	chip pan 001.jpg
Name:	chip pan 002.jpg
Name:	chip pan 003.jpg
  1. machine guards
    By billystein in forum Safety Zone
    Last Post: 10-16-2008, 10:45 PM
  2. Splash guards, lubrication collection help
    By klysons in forum MetalWork Discussion
    Last Post: 05-16-2007, 05:19 AM
  3. Splash Guards for Bridgeport Type Mills
    By widgitmaster in forum Uncategorised MetalWorking Machines
    Last Post: 05-15-2007, 06:54 PM
  4. way guards
    By DrStein99 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-14-2006, 03:39 PM
