587,175 active members*
3,195 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Multus B300w Sequence restart error on sub spindle
Results 1 to 7 of 7
    Feb 2011
    Hello,
    I am a newbie on this forum !
    We have a brand new Multus B300w machine on our floor. We are able to preform the sequence restart on the main spindle without any problems. But when we try to preform the restart on the subspindle the machine errors out with error "1741-20 chuck unclamp spindle 1".
    We have tried everything from closing the main spindle chuck with the foot pedal to programing in an additional command to close the chuck.
    I know it must be a simple g or m code that is missing from the program.
    Thanks in advance,
    Robert
    Feb 2008
    586
    Does the "clamped" light turn on for spindle 1? IF not, a proximity switch may need a slight adjustment.
    Jun 2008
    372
    ^^^ What he said ^^^^ there must be confirmation of chuck Clamp/Unclamp
    Mar 2009
    1982
    it is safety interference with restart capability. Obvious, when restarting program for subspindle, the main spindle is empty. Correction of limit switch is risky - empty chuck will be misunderstood as clamped.
    I guess, report to Okuma and wait for solution. There are some ways to cancel chuck interlock, sure.
    Jun 2008
    372
    "empty chuck will be misunderstood as clamped"
    Not possible on a CE spec machine
    Mar 2009
    1982
    easy, if You move proximity sensor. New machines, having hydraulic pressure monitored, maybe yes, cannot be cheated that way. Lathes with OSP U control (and older) have only proximity switch signal to see if chuck is clamped or not.
    Is the "CE" label used for machinetools in USA?
    Feb 2011
    To get running again we removed the part from the subspindle, adjusted the limit switches, and loaded a new part into the main spindle.
    Thanks all for your help..
  1. Multus B300W fiasco
    By mstlouis in forum Okuma
    Last Post: 06-29-2019, 10:28 AM
  2. Restart sequence in U-10
    By edufer1 in forum Okuma
    Last Post: 11-25-2010, 02:31 AM
  3. Replies: 19
    Last Post: 08-01-2010, 08:25 PM
  4. Replies: 1
    Last Post: 04-19-2009, 08:50 PM
  5. Mits M-v5cn,meldas 600 control,duplicate tool registration error or out of sequence
    By davissammy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-04-2008, 04:39 PM
