587,328 active members*
3,473 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Nardini Fast Trace fanuc 20-T Edit Mode
Results 1 to 10 of 10
    Aug 2010
    I have a Nardini Fast Trace with a fanuc 20-T control and when I reference the lathe to home the machine will no longer allow the edit, mdi and other modes. They are available before reference. We bought this machine and the previous owner put a new oiler on and I think they messed up a wire or parameter setting. It will run with the simple guidance mode with a small 5 point program or in manual mode but not in mem mode.
    Thanks Eric
    Aug 2010
    Thanks you for the post.
    Hi guys, Im a newbie. Nice to join this forum.
    __________________
    Watch The Expendables Online Free
    Dec 2005
    54
    Eric, i also have a nardini fast trace with 20-t, my knowledge of parameters, blah, blah, is poor but mine is set up and running well, pm me if youve not resolved this yet, at very least i can help compare my properly running machines parameters and settings with yours
    Aug 2010
    Update: We have contacted Fanuc USA and they gave us some info and we will try looking at the PMC Ladder logic display and see what we can find out with a friend who is an electronics guru. Also a parameter setting as well.
    Eric
    Aug 2010
    Update: Well we have discovered a missing battery (one of two) and have decided to check this issue first. It implies that the reference may not be working correctly with out it and a proper re-zero of the machine.
    Eric
    Aug 2010
    Figured out how to send a program as 7999 which is what the teach program uses. If I send a program over and then reference it then I can run the program. Now all i need is a Gibbscam post processor for the nardini fasttrace and FANUC 20-t controller
    Eric
    Feb 2018
    Quote Originally Posted by Eric05 View Post
    Eric
    Any chance someone could copy the manual for me, Happy to pay. I need a manual for a fastctrace with a 20T control, thanks
    Dec 2017
    7
    Re: Nardini Fast Trace fanuc 20-T Edit Mode
    [email protected] send parameter please
    Dec 2018
    4
    Thanks Eric
    I
    I know this thread is super dead, but I have the same problem with my Nardini lathe. Anyone ever come up with a solution? I've been going through the ladder logic and found that there is a BIT called STL, and a BIT called MK=MG. I believe that this means that it is copying the Machine Key Mode data over to the Machine Guidance registers and now ignoring the Machine Key Mode data. Once the lathe is referenced to home, MK=MG bit is on and both multi position switches behave in the same manner.
    I checked the wiring of my lathe versus the provided diagram and it matches. (though it is labeled in Portuguese, so I don't have 100% confidence, but the pin numbers do match.)
    MG=MK bit has the address R0006.5
    STL bit has the address F0000.5
    I don't know if either of these two addresses can be altered without burning a new ROM. If anyone knows the answer about changing bit states for R or F addresses in a Fanuc 20 control, I would be happy to hear about it. I am aware that system parameters are editable, but I couldn't find these two bits in the system parameter list. I believe that the PMC has a different list of parameters than the system.
    This is all pretty esoteric, and this isn't a terribly common lathe. The chances of someone having the solution is fairly small I imagine.
    Have a good day all
    --Tom
    Feb 2019
    I am too having trouble with the mode switch operation.. I doesn't do anything.. seems that everything went to the guidance switch.. NEED HELP!!
    Thanks Eric
  1. Nardini fast trace Fanuc 20T control
    By LIGAMEC CORP. in forum GibbsCAM
    Last Post: 04-11-2014, 08:04 PM
  2. Fast Painting Mode workaround?
    By kbmyers in forum SprutCAM
    Last Post: 01-29-2013, 04:01 AM
  3. Nardini Fast Trace Fanuc Servo Parameters
    By mferris in forum Uncategorised MetalWorking Machines
    Last Post: 10-25-2011, 05:01 AM
  4. Fanuc Om Edit mode problem
    By Selimsalim in forum Fanuc
    Last Post: 03-06-2009, 11:50 PM
  5. DX-32 freezing in edit mode?!?!?
    By mlbz420 in forum Bridgeport / Hardinge Mills
    Last Post: 05-16-2007, 12:37 AM
