587,753 active members*
3,084 visitors online*
IndustryArena Forum > Material Technology > Composites, Exotic Metals etc > Carbon fibre threading improvements?
    Nov 2022
    hi all, We make many carbon fibre components, some with around 80 tapped holes blind and through in a range of sizes. these are currently thread milled with ticn-coated treadmills.
    This works well but is very very time consuming keep adjusting cutter comp to size them.
    ~Also puts all the pressure on the machinist to keep adjusting cutter comp as you know one digit wrong and the part is scrap. One of our ops is around 30 mins to run the whole thread milling program, then adjust and re-run, hours of work...
    Are there any taps out there for rigid tapping in carbon fibre that produce a good thread and not de-laminate the top few layers of carbon.
    We have tried with many different taps but find they always slightly de-laminate the top skin, on safety critical areas in our industry this is not acceptable.
    any help or experience would be great
    Mar 2008
    683
    Re: Carbon fibre threading improvements?
    Countersink the first few layers with a diamond abrasive countersink first. Then try to run a tap. But it seems to me the nature of laminated carbon will not lend itself to using regular taps since it will just delam the fibers rather then cut them.
    Jun 2015
    4160
    hy k-turner warenb's idea about the countersink seems nice; even so, a countersink could lead to same delamination; carefull with not visible delamination
    is one thing to plunge a countersink/tap, and another to interpolate the chamfer/thread, thus there is a balance between cutting forces and time
    to make that tap work with less delamination, it has to be more sharp, have longer entrance ( conical zone ) and less calibration teeth ( cilindrical zone ); you could take a tap and grind it so to have a single helix, thus it's cutting force will be as low as possible, but you may not be able to guide it if there is overhang
    to make your process work, you simply need to find a tool that has cutting force as close as your actual method of intepolation you will have to test many taps
    i suggest :
    ... checking the consistency of the process, and mapping things as needed, so to identify & eliminate time waste
    ... avoid error related to inputs, by using a macro that checks offset deviation, and an incremental aproach for final finishes, that simply increases the toolpath radius, without requiring the operator to always modify ++++ then ---- at a new part; if process is stable, is possible to bound it's corections, and speed up or at least partially replace operator's actions
    such actions can ease the operator, and works as long as deviations follow a previsible pattern; there may be burs, lack of thread rigidity
    at 1st glance, time seems fine
    you can boost feed by adding one more tooth, thus instead of experimenting with taps, simply use denser threadmills, at least for orughing
    consider also finish with different tool / kindly
    Jul 2018
    6492
    Hi KT - Do you have design input to the parts? If so consider using a CF veil or glass veil on the top layers. This will produce a layer that has less chance of delaming. Veils come in 25gsm thru to 100gsm and can be very useful for this sort of thing.... Peter
    Mar 2008
    683
    This gives me an idea. I have a whole box of form metric mills. I'll get some scrap and see how it works.
  1. CNC tapping of carbon fibre improvements?
    By k_turner in forum Drilling
    Last Post: 12-20-2022, 12:31 AM
  2. CNC filament winder(carbon fibre)
    By wallygator99 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 10:49 PM
  3. Anyone cutting carbon fibre sheets?
    By techasist in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-10-2009, 01:19 PM
  4. looking for a supplier of Carbon Fibre Hard sheet
    By acidcustom in forum Composites, Exotic Metals etc
    Last Post: 07-22-2007, 08:50 AM
  5. Routing Carbon fibre laminate
    By kong in forum Composites, Exotic Metals etc
    Last Post: 04-09-2007, 05:08 AM
