587,834 active members*
3,011 visitors online*
    Jan 2014
    44
    Problem with "Feedhold"
    Hi fellas,
    I have a cnc 3020. Recently I noticed that if I press "feedhold" if I need to pause the toolpath for something that when I do this the bit will drop into the material surface about 1mm. It didn't do this before. I'm just trying to figure out what this could be and how I can troubleshoot this issue. Any assistance would be greatly appreciated. Thanks in advance!
    Feb 2007
    4553
    Re: Problem with "Feedhold"
    Us ill,
    1: The end mill is pulling out of the collet.
    2: The spindle bearings are bad, check the end play.
    3: The stepper motor is not holding the axis position.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2014
    44
    Jalessi, I checked the collet and it looks to be fine. My spindle doesnt seem to have any end play when I manually try to move it up and down. So possibly it is the stepper motor. I dont know what else it could be. I have these cheap chinese stepper motors so im thinking it is this one. Is there any way to be sure. Here is a picture of the Z axis stepper motor label. Thanks again sir!
    Quote Originally Posted by jalessi View Post
    Us ill,
    Jeff...
  1. Replies: 21
    Last Post: 01-13-2014, 04:10 AM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
