587,699 active members*
3,597 visitors online*
Thread: Oiler issues
Results 1 to 8 of 8
    Dec 2009
    594
    Oiler issues
    The oil pump that came with the mill broke on the bottom lever casting a couple of years ago, and I had John send me a replacement. Different "brand" but same Chinesium construction. The replacement worked for a while but then started leaking from the bottom , so I would fill it every session with just enough to deliver oil. I finally got tired of that and ordered a replacement from Amazon. This dud doesn't even have check valves! I swapped the checks from the leaking one but nothing is getting pumped out. I asked for a refund today via Amazon website, but if I have to pay to ship it back I'll east the $30.
    Can anyone recommend a good replacement pump and vendor?
    In the interim I made swap the lever casting from pump 2 to pump 1 and see how that goes.
    Jan 2016
    386
    Re: Oiler issues
    Several years back LeeWay purchased an automatic oilier for his Pulsar. It might be worth a try $116.00
    https://www.cnczone.com/forums/novak...neering-4.html
    https://www.ebay.com/itm/17101145709...%3AMEBIDX%3AIT
    Jun 2018
    84
    Re: Oiler issues
    I just installed one of these on my 1100M to oil the Z axis slide ways and ball nut. Granted it's a cheap import pump but it does work. If it breaks I'm out only $20.
    Aug 2007
    359
    Re: Oiler issues
    I had problems with mine leaking, too. This is what I did. If it's still leaking, it's only a drop now and then, but I don't use the mill everyday. I have an automatic one to install, just haven't gotten to it.
    Don't have to be too bright to be me
    Dec 2009
    594
    Re: Oiler issues
    Quote Originally Posted by pastaman View Post
    That's what I bought that doesn't work.
    Jan 2016
    386
    Re: Oiler issues
    Quote Originally Posted by mklotz70 View Post
    If the oilier on my Pulsar is any more than half full it drips.
    Jun 2018
    84
    Re: Oiler issues
    Quote Originally Posted by kvom View Post
    I agree. The cheap oilers you and I bought, and others, are of questionable quality. My backup plan when my $20 dollar oiler fails, and it will, is to replace it with a pre-owned Bijur manual oiler I bought on eBay a couple of years ago. Right now it's in service on my manual mill.
    Dec 2009
    594
    Re: Oiler issues
    Problem solved for the instant. The original oiler failed when the plastic collar that attached the lever to the base cracked. The metal one from the leaking oiler was a screw in replacement, so I'm back in business.
  1. Automatic Oiler
    By SCzEngrgGroup in forum Novakon
    Last Post: 03-02-2018, 04:43 PM
  2. Automatic Oiler
    By SCzEngrgGroup in forum Tormach Personal CNC Mill
    Last Post: 05-01-2017, 09:26 PM
  3. Oiler help
    By SFIYA in forum For Sale Only
    Last Post: 11-18-2013, 06:01 PM
  4. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-19-2010, 04:21 AM
  5. One shot oiler
    By Bubba in forum Uncategorised MetalWorking Machines
    Last Post: 12-01-2009, 03:39 AM
