Hello,
I have a Compumill 1500 CNC Mill. It has Copley servo controls, and runs from a PC (486). There is an interface board (a CONTEC PIO-24/24 (PC)) that has two dip switches that assign it a hardware address. In an attempt to upgrade the computer, I had to change the hardware address. The upgrade was not successful, and I made the mistake of not writing down the original address.
Now I am just trying to return the machine to its original set up. The computer works fine, but cannot communicate to the rest of the machine. This doesn't suprise me, because I'm fairly confident that the address is not correct.
So, if anyone has one of these machines or the documentation for one, I would be greatly appriciative if you could tell me what the address should be. The two dip switches are blue and marked SW1 and SW2 on the Contec board. I can also provide pictures if that will help.
Thank you
