587,172 active members*
2,875 visitors online*
    Oct 2004
    8
    Question Axis Drive Fault
    Please Help.
    I have a Bridgeport EzPath late and have an axis drive fault. The machine will not home. I have had several people to look at my machine (at great expence) and no one can tell me anything more than it mighht be the drive amplifier card.
    To start with the plug to the x axis servo motor was burnt, the plug has been replaced, but the fault remains. Where is the next place to start looking for solutions.
    :drowning:
    4826
    The most common advice you'll get if you do your own trouble shooting is to swap motors, then cables, then drives, one at a time. The idea is to try to isolate the problem area through a process of elimination. This is your best bet. Even if you have to stock a spare motor and drive, it can be worth it when you're broke down.
    You need to take suitable precautions when doing this. The safest method is to remove the motors from the screws they are driving, in case you get a runaway because your encoders are not hooked to the correct axis when doing this kind of swap.
    Oct 2004
    8
    Thanks HuFlungDung,
    I tried your fault finding procedure without sucess, however
    I have since replaced the axis drive card (at considerable expence) and this has fixed the problem.
    Mar 2004
    564
    Check the current your drawing!!!!!! dont damage another drive due to tight ball screws or ways that are worn out and stressing the the controls...there is a reason your drive got fried!!!!!
  1. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  2. C axis fault
    By Rudee in forum Fadal
    Last Post: 05-13-2005, 05:58 PM
  3. Spindle Drive Fault
    By n5jjr in forum DNC Problems and Solutions
    Last Post: 03-31-2005, 03:26 PM
  4. My Lathe project; might CNC it one day
    By Stevie in forum Uncategorised MetalWorking Machines
    Last Post: 06-22-2004, 02:27 AM
  5. size of 4th axis drive
    By converterk in forum Centroid CNC Control Products
    Last Post: 06-07-2004, 04:01 PM
