Hello all,
I need help to setup the clamp / chuck in Solidcam turning.
Going through the motions until I get the message that the tool will interfere with the clamp (chuck I presume).
How do I set up or see the clamp / chuck?
I am working my way through a Tutorial called Axis.
Normally I would expect to be able to set the length of the object I want to turn.
Say a chess pawn, that will have a specific height when turned out of aluminum stock.
Any ideas how to set the clamp for cylindrical stock?
Regards
Jos PA0AMX
