Hello experts,
Thanking in advance for your favour advices for my project here :
[ pls take a look at the attached pictures ] :
Material : mild-steel metal sheet , thickness in between 1.6 to 2 mm.
Which the proper and best result :
- Forming first and then weld the edge ?
or
- Welding the edge and then forming the colar.
Pls advise the proper welding process type.
It will very helpfull if you have some links for metal colar forming / shaping and welding.
Again, thank you very much for your kind help and attention.
warm regards / jbd
