587,299 active members*
3,474 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > BALLSCREW vs. RACK & PINION vs. PRECISION ACME SCREWS
    Jul 2005
    107
    HI
    I'M TRAYING TO DECIDE WICH OF THESE, CAN I USE.
    I DON'T WANT TO MUCH BACKSLASH
    I DON'T WANT TO SPEND TONS OF MONEY ALSO
    PLEASE ADVISE ME
    I WILL BUY ALMOST EVERYTHING FROM:
    WWW.MCMASTER.COM
    Aug 2004
    2849
    ACME screws are more accuracte then most ball screws and cheaper. I believe that the precision ground ball screws are close in accuracy. ACME screws are not as efficient as ballscrews.
    Rack & pinion is in a separate category.
    Jul 2008
    For X axis of over 4000mm is rack & pinon is prefferd or ballscrews give the merits & Demerits
