I have seen some reference to homing in a few threads, but I have a question I haven't seen the answer for yet.
I have my slow zone speeds set to 5%, 5% on X and Y axes. While referencing home, the speed is nice and slow, as are my slow zones for soft limits.
What about after the machine coordinates are already setup and the GOTO Home button is pressed. The machine races to the home switches at full speed (409"/m) and slams to a stop. It does not hit a hard stop or the switches themselves. It comes to 4mm away from the switch as it should. (the switches are magnetic I believe).
Once stopped, the limit switch lights are on red (cable end of switches have led's) and I have to reset from a tripped limit. That means I need to manually push the gantry and Z plate away from my X and Y home switches in order to reset.
Debounce set at 2000 in gen config.
Is it supposed to do this? Being the user is asking the unit to go home, maybe it is (??) Am I just missing something really simple here?
Thoughts?
