587,331 active members*
3,120 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Does anyone have any good jet engine plans?
Results 1 to 19 of 19
    Oct 2004
    I owned a machine shop for years and have became disabled. Now I still have a decent CNC hobby shop and would like to build a jet engine if someone has any good plans.
    Nov 2003
    634
    http://www.wren-turbines.com/index.html
    http://www.5bears.com/tprop.htm
    Maybe these sites will get you in the right direction
    Mar 2004
    1661
    No plans, but a great reason to build one!
    http://www.asciimation.co.nz/beer/
    :cheers:
    --Sven
    383
    I really recommend the Wren MW54. You can scratch-build as much as you want, but if you get stuck, each and every individual part can be purchased from Wren, who are good folk in G.B. The MW54 is a well-proven design and runs sweet. I have built 2, one from sheet/bar stock (except the compressor, turbine, and NGV), and one from a "kit" to act as the gas generator for my turboprop.
    The KJ66 is another proven design with a wide following. The KJ is an 18-20lb class turbine, while the MW54 is a bit smaller at 12-14lb thrust.
    Either of these would be a wise choice. There is nothing exceptionally hard in a small turbojet. It took three months of spare time to build my first, while one of my average IC engine projects can take 1 yr or more.
    Good luck! They SOUND and SMELL just like their big brothers. The sound is especially cool. I don't have the skill to fly one in an R/C model... about the best I can do with R/C is an electric foamie!!
    Apr 2005
    281
    Just to add another site for plans. They are for the KJ66 and all parts can also be purchased from there or other sources. It is a popular engine also with home builders but the Wren is also that way now.
    http://www.artesjet.com
    John
    Feb 2007
    Jet Engine Plans
    There are plans for a jet engine similar to a KJ66 in Autocad format available for free at http://www.john-tom.com/html/Jet.html
    They are from a German university project. There are also KJ66 upgrade plans
    Best regards
    John
    Oct 2006
    120
    i 2nd or 3rd the MW54 for the same reasons that of Swede.
    any part you cant be azzed to build, you can buy from Wren. plus they are on the end of a phone to answer any stupid home builder questions.
    heres a link to the 54 I'm building http://www.cnczone.com/forums/showthread.php?t=47441 so you can see whats involved.
    it was meant to be running for last month, but i got a mill instead and ran out of money to get the turbine and NGV. :-(
    15362
    Hi flyguy 1254
    I saw some plans on Ebay that looked good they had losts for sale I don't have a link
    but they should be easy to find
    Mactec54
    Mar 2007
    30
    With those updated kj66 plans do you use the same turbine wheels and compressors and such as the original as they are not in the drawings? Thanks
    Jun 2006
    this book is exellent
    [ame="http://www.amazon.com/Home-Built-Model-Turbines/dp/B000GY066S/ref=pd_sim_b_title_2"]Amazon.com: Home Built Model Turbines: Books[/ame]
    Mar 2007
    30
    I have that book and will second that it is great
    Jan 2007
    634
    How big do you want to go? I have some plans for some pretty simple pulsejet and ramjet engines. I think they were meant for an ultralight helicopter or autogyro or something. They are bigger than those for model airplane use, but a lot cruder and less refined - simple to make though. The pulsejet will power a moped or kart frame quite nicely if you just want to wake the neighborhood while skipping the aircraft part!
    Apr 2008
    5
    HURRICANE PLANS BEING PUBLISHED IN MAGAZINE
    AUSTRALIAN MODEL ENGINEERING MAGAZINE IS PUBLISHING PLANS AND AND AN EXCELLENT SERIES OF ARTICLES ON THE BUILD PROCESS OF THE HURRICANE MODEL GAS TURBINE. I HAVE SUBCRIBED TO THE MAG AND ORDERED THE BACK ISSUES JUST FOR THE PLANS AND BUILD ARTICLES. YOU'LL NEED PUBLICATION 135 ONWARDS. WOULD APPEAR THAT IT IS A RECENT DESIGN IMPROVEMENT ON A PROVEN UK DESIGN.
    WEB SITE FOR MAGAZINE is http://www.ameng.com.au
    UNFORTUNATLY THE WEBSITE DOESNT GIVE ANY DETAIL ON THE ARTICLE BUT I'M SURE IF YOU EMAILED THEM THEY WOULD PROVIDE MORE DETAIL TO HELP YOU DECIDE IF IT'S WORTH THE PURCHASE. HAVING NOW READ THROUGH IN DETAIL THE BUILD PROCESS I CAN SAY THAT PLANS ALONE ARE INSUFFICIENT FOR EVEN AN EXPERIENCED MACHINIST IF YOU WISH TO BUILD A TURBINE WITH ACCEPTABLE THRUST/WEIGHT AND THAT'LL HAVE AN ACCEPTABLE SERVICABLE LIFE BETWEEN REBUILDS. IMPORTANTLY CASTINGS FOR THE GUIDE VANE AND TURBINE WHEEL ARE NOW AVAILABLE FROM EUROPE AND AUSTRALIA AT WHAT APPEARS TO ME TO BE REASONABLE PRICES. COMPRESSOR WHEEL IS STND GARRET TURBO COMPONENT AVAILABLE WORLDWIDE
    HOPE THIS HELPS IN YOU'RE RESEARCH
    Jan 2007
    5
    i have the complete books.. including the model turbo-prop engine for home construction by kurt schreckling.. do you have landing gear plan of aircraft jet plan or ecu plan or other that we can trade..?
    Feb 2008
    hi vicki
    nice boks that you have, i've send a PM to you..
    regards
    Nov 2007
    5
    I just want to say thanks for allowing me to be part of this cnc forum. I am a self taught machinist. I have not posted because I have had nothing to add but I have learned a lot just by reading. I am interested in model engines both steam and internal combustion. I was thrilled to fine sites here for plan that I feel I am capable to build. My hope is to learn enough to hand down my knowledge to my children and grandchildren. I am 67 years old. Thanks again.
    John McCain
    Jun 2007
    3734
    Smile More places to look
    Feb 2008
    the plan,
    iv found those books on rusian forum,
    amazing rusian people..
  1. The Most Powerful Diesel Engine in the World!
    By WallCrawler in forum Community Club House
    Last Post: 07-25-2010, 07:50 PM
  2. Nice jet engine
    By cncadmin in forum Hobby Discussion
    Last Post: 03-18-2007, 02:08 AM
  3. Replies: 38
    Last Post: 09-05-2006, 02:44 PM
  4. 4 stroke engine: castings & plans
    By motordude in forum I.C. Engines
    Last Post: 03-02-2004, 05:08 PM
