587,490 active members*
7,245 visitors online*
    Oct 2007
    56
    EMI shielding
    We have some machinery using old Phillips Scales and pulse conditioners. Problem is the pulse conditioners are very susceptible to noise interferance. Contactors chattering. Solonoids energizing ect...
    What are some shielding tricks that I could try. I found these iron core donuts that I slid over the feedback cable. This seems to help. What is the theory behinfd the iron donuts. These were on the feedback cables from another machine from Europe
    Jan 2006
    738
    Those donuts help eliminate high frequencies from the wire they are around. Without going into detail, they lower the maximum slew rate of the current passing through them by impeding the change in magnetic flux around the wire.
    Try to keep the susceptible wire away from wires that have high current switched loads if possible. You can also put the same "donuts" around the output and input leads on the contactors to keep the pulse noise from propagating down the wires where it can radiate out.
    Steve
    24220
    The best thing is to try and kill it at source, for AC solendoids etc, use an RC snubber and for DC use a reverse EMF diode, across the coil in each case.
    Snubber link http://www.cnczone.com/forums/showth...hlight=snubber
    Al.
  1. Use of shielding gas on wood....
    By sntlewis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-13-2007, 10:06 PM
  2. Need industrial switch with good shielding
    By mrnicks in forum Computers / Desktops / Networking
    Last Post: 03-08-2007, 01:42 AM
  3. Connection of shielding
    By cncuser1 in forum CNC Machine Related Electronics
    Last Post: 06-18-2006, 01:57 AM
  4. Plasma noise (shielding)
    By AZCoyote in forum Waterjet General Topics
    Last Post: 01-16-2006, 03:19 AM
  5. RF shielding against plasma
    By HuFlungDung in forum DNC Problems and Solutions
    Last Post: 11-18-2004, 04:36 PM
