587,475 active members*
3,526 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > FlashCut CNC > FlashCut error message: lost connection with signal generator! HELP!!!
    Aug 2010
    Unhappy FlashCut error message: lost connection with signal generator! HELP!!!
    I use FlashCut CNC ver. 2.0.9 to cut sheet metal using a Hypotherm Plasma Cutter. I have started getting an error intermittently that states I have lost the connection with the signal generator, try turning off and on to reset/check connections etc. I have been unable to pinpoint where the problem is, but suspect it is in the Flashcut Signal Generator Box. I ordered a new 9 pin cable in the hope that the solution is that simple but have not received it yet. Has anyone else had this problem and can offer recommendations to fix?
    Oct 2004
    188
    i had the same problem for awhile. i droped the communication baudrate down one level and it went away. still not for sure that was the problem. but it has not happened since.
    Aug 2010
    Baudrate?
    Thanks for the reply. What baudrate did you set it at? I looked at this as and was not sure if I should set it lower. I did get a new 9 pin cord and ran the power cord separately and that seemed to help. Thanks,
    Carrie
    Oct 2004
    188
    i think before i had it at 115k baud and dropped it to 57.6k baud on version 2 i since have updated to version 3 software and a new chip for the 401 controller. it helped alot with the communication problem. but a good cable will help out as well.
  1. Iron Cad
    By sanjiv in forum Uncategorised CAM Discussion
    Last Post: 10-21-2008, 02:51 AM
  2. anyone know where to get a used iron worker?
    By mik32176 in forum Bending, Forging, Extrusion...
    Last Post: 02-01-2007, 11:45 PM
  3. Yet another iron in the fire...
    By BobWarfield in forum Charter Oak Automation Support Forum
    Last Post: 07-03-2006, 05:27 AM
  4. RFQ For a Mountain Bike part
    By Bender in forum Employment Opportunity
    Last Post: 08-18-2005, 07:38 AM
