587,913 active members*
3,601 visitors online*
    Sep 2007
    39
    Smile Haas rotary setup
    Hi y'all, hope the holiday has been good for you.
    I have a Haas Hrt6a I need to run on a VF5.
    Having trouble entering the HRT6A number in settings mode, (4TH axis enable), When it is flashing 'NEW', I type in number, hit enter, get 'invalid number' message. Any hints? Does machine need a drive or configuration for 4th axis.
    Thanks everybody
    Dec 2008
    717
    What "number" are you typing in?
    Unless they have changed things you should be scrolling through a list of all the Haas rotary tables (in the settings pages), then hitting write/enter to select it and enable it.
    Tim
    May 2010
    83
    Quote Originally Posted by bigbobr View Post
    Thanks everybody
    This may sound stupid, but make sure the e-stop button is pushed in or it won't allow you to enable the axis.
    Good luck and happy new year!
  1. Tipping rotary haas rotary axis
    By mfpuller in forum Mastercam
    Last Post: 04-04-2011, 04:16 PM
  2. rotary table setup
    By Michael Devine in forum Linear and Rotary Motion
    Last Post: 08-31-2010, 11:09 AM
  3. DESKCNC ROTARY SETUP
    By preshaji in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-05-2008, 09:27 PM
  4. Rotary Table Outrigger setup
    By walter in forum Mechanical Calculations/Engineering Design
    Last Post: 11-08-2005, 03:19 AM
