Originally Posted by
joeavaerage
To be honest I would be prepared to bet that if your 23 size 425oz.in steppers are low inductance, and I strongly suspect they are, then they are likely better than any 34 size stepper you could get anyway.
You are right to be concerned that a heavier machine might require more powerful motors, however the truth is 425oz.in steppers can and do a sparkling job even with heavier machines. You can always
gear them appropriately, which may count against your top speed, but they should have no trouble accelerating a heavy machine. If you are cutting wood and plastics then you might well miss the top speed,
but if you want to cut aluminum your cutting speed will necessarily be fairly slow anyway, and thus loss of top speed is a minor inconvenience.
Its time to decide what sort of machine you want, a fast lightweight machine for wood and plastics or a heavy albeit slower machine for aluminum. Just remember that if you choose a lightweight and fast machine
that it'll be fine for wood and plastics....but you'll be very disappointed should you try the occasional aluminum job, it will just not be stiff enough. Alternately if you make a machine stiff enough for aluminum
it will still do wood and plastics with ease, even if a little slower.
Its the capacity to do aluminum (or worse steel) that adds very much to the cost and complexity of the design, making a stiff machine is costly.
Craig
