587,163 active members*
3,510 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Need Spindle To Turn While Chuck Is Open
Results 1 to 18 of 18
    Dec 2007
    8
    I have a basic 370 with a FMB feeder and I need the spindle to slowly turn while the chuck is open so hex bar can be loaded. How do I bypass the chuck open alarm?
    Aug 2011
    2517
    normal Okuma codes are.....
    for sub spindle
    M246/M247 - sub spindle interlock release off/on
    M248/M249 - sub spindle chuck close/open
    for main spindle
    M184/M185 main spindle interlock release off/on
    M83/M84 main spindle chuck close/open
    Dec 2007
    8
    fordav11
    Thanks for the reply. I have used those main spindle M codes and had no luck.
    G97 S5 M04
    M185
    M84
    M436
    M05
    M83
    M184
    Feb 2009
    6028
    Try M51. That used to be for chuck air clean out, so it would jog at a low RPM with the chuck open. Not sure if it works any longer.
    Aug 2011
    2517
    I wish I has a chuck air clean out code on my machine. I'm forever blowing out the crap in sub spindle with air gun after each part is complete. Pain in the ass
    ok if M184/M185 does not work tell us which Okuma control you have.....
    Dec 2007
    8
    The controller is a OSP-P200L. I played around with the machine today and could not get it to read past the M185 line. No matter where I put the M185 in the program it would stop on that line and never had a alarm.
    Aug 2011
    2517
    No alarm suggests the machine is waiting for something to happen.
    If you leave it running for 5-10 minutes do you receive an alarm or timeout message?
    I have the full OSP-P200L manual set here in pdf. The M codes are correct.
    From the manual......
    Chuck open/close interlock release command
    M184 .... Chuck open/close interlock release OFF command
    M185 .... Chuck open/close interlock release ON command
    Example transfer program
    G13
    G140
    G00 X800 Z800 W800
    M185 M247
    M249
    G00 Z0 W30
    M151
    G94
    G29 PW=30
    G22 W0 D5 L2 F250 PW=20
    M248
    M84
    G04 F2
    G00 W30
    G28
    G00 Z800 W800
    M150
    M184 M24
    P10
    G14
    G140
    P10
    M02
    Dec 2007
    8
    Worked on this problem a little more today and used the airblow m89 & m88 and the spindle would turn like I wanted but I was getting a 3718 or 1740-1 alarm as the feeder was pushing the bar through the chuck.
    Apr 2009
    1262
    Looks to me like your bar feeder is the culprit. Many of them are looking for a spindle zero speed (provided by the okuma) in order to feed. Since you are getting a Coupling device error or external Chuck clamp alarm, I'd look at the feeder to see if you can change a parameter to allow rotation or re-wire if need be to allow it.
    By the way are you using the Okuma bar feeder interface? If you are, double check your bar feeder parameters to make sure the chuck rotation interlocks are off. If you have the system link OFF and try your interlock release codes, do they work?
    Best regards,
    Sep 2011
    104
    M185 should work if the machine is equipped with it as it is an option!
    Dec 2007
    8
    gunda
    I worked on this problem for several days and I'm thinking I did use the M185. I think the bar feeder needs to be rewired.
    Jun 2011
    124
    Hey fordav11! Would you be so kind to post a link to the p200 manual PDF!!! I would be so grateful!
    Aug 2011
    2517
    its not online. the manuals come on a CD that ships with any new Okuma CNC machine.
    Jun 2011
    124
    That's cool! Thanks anyway! No harm in asking! I'll find one somewhere!
    Nov 2007
    38
    If the zero speed signal is the problem I wonder if inputting a M63 "Ignore spindle rotation M code answer" would solve the problem?
    Quote Originally Posted by thays View Post
    today there was the same problem I found in the machine itself a document with m codes and code m391 helped me.
    it should be used in one line
    example : m391 m3 s500
    Apr 2009
    1262
    Re: Need Spindle To Turn While Chuck Is Open
    fordav11
    G97 S5 M04
    M185
    M84
    M436
    M05
    M83
    M184
    I noticed that you have S5 as your spindle speed. You cannot go below 50 RPM or you will not get confirmation that speed has been reached. You also need to have the M185 BEFORE you try to start the spindle or the interlock is still effective - although if your chuck is clamped you would be OK.
    Experience is what you get just after you needed it.
    Apr 2009
    1262
    Quote Originally Posted by jamessiffel View Post
    Which manual are you looking for? Programming? Special functions? Alarm?
  1. Chuck will not open
    By bruiserba in forum Okuma
    Last Post: 08-30-2019, 07:32 PM
  2. Chuck open signal needs to be reversed
    By Don18P in forum Fanuc
    Last Post: 01-07-2013, 04:44 PM
  3. run lc 30 with open chuck
    By martin269 in forum Okuma
    Last Post: 07-08-2012, 05:05 AM
  4. Replies: 3
    Last Post: 10-04-2011, 01:50 PM
  5. Turn spindle chuck unclamped
    By FUN4ME in forum Haas Lathes
    Last Post: 04-22-2010, 07:36 PM
