587,646 active members*
2,957 visitors online*
Results 1 to 13 of 13
    Feb 2011
    210
    G0704 or BF20L
    G0704 is $1100 plus $100 shipping. Not sure about the extra shipping cost to canada.
    Machine Tools Warehouse (in Canada) is 1 hour from me. They got BF20L $1250.
    So price is about same for me to my door. And the specs are almost same.
    I am going to use it for aluminum.
    Accuracy maybe more important than rigidity in my case.
    Any advice will get me closer to putting my money down.
    Oct 2010
    266
    99% the same machine. with you being in canada im sure the price of the g0704 would be more than the bf20 that you could pick up.
    id say the easier solution would be to go with the bf20. that is of course based on availability between the two and how long you are willing to wait if necessary
    Feb 2011
    210
    It looks like I can pick it up with a F150?
    Feb 2011
    210
    Quote Originally Posted by jeremy0203 View Post
    Are you saying they are made by the same manufacturer, or you are just saying 0704 is BF20L's clone?
    The only thing I would have against the BF20L is the MT2 spindle.
    If you ever have thoughts of running TTS tooling, you won't be able to with MT2.
    That's a pretty small taper for a machine like this if you ask me, they should have at least used MT3.
    The G0704 is R8.
    Hoss
    Feb 2011
    210
    What is the maximum tool diameter MT2 can take?
    Can MTW just change it to MT3, or it is part of the "head"?
    Thanks Hoss
    MT2 collets go to 1/2 inch, TTS tools have 3/4 shanks.
    They don't offer any other options on the page like they do with their other mills so I'd say no, it's MT2 only.
    There is the King R8 model in Can. you could consider.
    King Variable Speed Bench Mill with Digital Spindle Speed Indicator 1HP 110V 1PH
    You can get along just fine with MT2 especially if you use ER collets but the TTS
    is nice for power drawbars.
    Hoss
    Feb 2011
    210
    Hi Hoss
    If I go with BF20L, can I still use your CNC convention kit? Start watching your videos, enjoying it so far :-D
    Do you sell CNCed 0704?
    The bf20l is a little different and would need the parts tweaked to match.
    No I don't sell cnced 0704's or parts, just the guide plans.
    Hoss
    Feb 2011
    210
    I can buy the plan and modify it to match BF20L then. I am pretty good at Solidworks. if just dimention change, I should be able to model up the mill and modify your plan.
    That all depends what did you mean by "tweak" :-D
    Quote Originally Posted by bonmotwang View Post
    Have a read here.
    http://www.cnczone.com/forums/1067052-post102.html
    Hoss
    Oct 2008
    2100
    Thanks Hoss
    An MT2 can hold pretty large tools if you use a collet chuck in it. I have seen them upto ER40. I think that will go upto atleast 1". I have an ER25 one for my noname mill drill and it goes up to 5/8". I like the collet chucks because its so much faster and easier to swap cutters than a direct insert collet. You do have to account for any additional runout though.
    Bob La Londe
    http://www.YumaBassMan.com
    Feb 2011
    210
    Quote Originally Posted by Bob La Londe View Post
    I am not cutting big stock. MT2 should be OK for me for most of the job.
  1. No Joy with my New G0704
    By DogWood in forum Benchtop Machines
    Last Post: 07-05-2016, 05:49 PM
  2. Optimum BF20L CNC conversion using the Smooth Stepper
    By Mad Welder in forum Benchtop Machines
    Last Post: 03-25-2013, 12:47 AM
  3. Optimum BF20L CNC conversion
    By JanHenning in forum Vertical Mill, Lathe Project Log
    Last Post: 03-11-2009, 05:09 PM
  4. elte spindle in bf20l
    By yioryos in forum Benchtop Machines
    Last Post: 01-25-2009, 06:47 PM
  5. OPTIMUM BF20L mill, z-travel exactly from table height ?
    By vroemm in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2009, 10:01 PM
