587,404 active members*
3,218 visitors online*
    Jun 2009
    146
    Function "Tracyl/Transmit"
    Hello!
    On the Siemens 840D controller I want to know the c-axis machining with the function "Tracyl/Transmit" what it looks like the G-code with a simple contour milling program with C-axis?
    So if someone appears to me, or make a link (if any) simple G-code, which includes milling on kontur with C-axis, with function "Tracyl/Transmit
    Is it possible to make on the 805 controller?
    Jun 2009
    146
    Can anyone describe the function of the C-axis milling (Maschine is the vertical lathe machine "EMAG VSC") "TRACYL / Transmit", for the controller 840D, if possible to do well on the 840C?
  1. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  2. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  3. "Fill circle" engrave function LaserCut 5.1
    By grzegorz1965 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-03-2008, 01:04 AM
  4. The "Blank FUnction"
    By Ken_Shea in forum OneCNC
    Last Post: 07-17-2003, 04:51 PM
  5. Using the "Difference" Function
    Last Post: 05-09-2003, 04:59 AM
