Solid models consisting of surfaces only, lack any 2d geometry until you extract an edge.
Also, the filetype you choose for export may automatically remove any lines and arcs that your working file does contain. So, you may need to export two files, one as the solid model, and another as a dxf containing text, dimensions, etc.
Or, your cam software may have a function to permit you to extract edges from your solid model.
