587,125 active members*
2,725 visitors online*
    Nov 2004
    11
    Haas TRT210 and Fanuc 21iMB
    Anyone ever use the RS232 and DPRNT with a Haas 2 axis indexer controller to control a TRT210?
    The controller manual says it won't work but goes on to show examples of how to program it.
    Will the 2 axis controller allow me to load and execute index moves via RS232 or do I need to daisy chain 2 single axis controllers?
    Nov 2004
    11
    Guess all the "experts" on this forum are stumped....
    If you want to know how to do this I can forward the info for a nominal fee.
    Otherwise figure it put for your self!
    Nov 2007
    1702
    I think you're asking in the wrong place. I would guess that most Haas owners who run 4th axis have built-in wiring. It's a common and relatively inexpensive option on most Haas mills (and it's bundled with other options making it even more common). Haas knows that a pre-wired, 4th axis machine will sell rotary products so they keep the entry cost low on that option.
    It's the built-in 5th axis that costs real money so most don't buy it unless they absolutely need it.
    If they're running a 5th, it's likely that they only have a single-axis controller. I can't imagine that many on here have the two-axis control. Heck, I didn't even know they made one until I found one of FleaBay.
    Have you tried calling Haas applications? They seem like they're pretty helpful.
    BTW: I see you got the same lack of response in the Fanuc forum. Are ya' gonna' drop by there and piss on them too?
    Greg
  1. FANUC,HAAS,SINUMERIK,MITSUBISHI CNC system Simulation
    By ziyoo in forum News Announcements
    Last Post: 08-03-2012, 05:55 AM
  2. Haas vs. Fanuc controller
    By bmac30 in forum Haas Mills
    Last Post: 06-23-2011, 11:55 PM
  3. Ge-Fanuc 21imb and HSM
    By serkanc in forum Hard / High Speed Machining
    Last Post: 10-13-2009, 01:40 PM
  4. FS21iMB and Haas TRT210 indexer
    By 2alpha in forum Fanuc
    Last Post: 01-03-2008, 10:33 PM
