587,657 active members*
3,246 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco BMC 20 - Ultimax 3
    Mar 2008
    I am trying to connect my Hurco BMC 20 to a PC for transferring CAM programs via Windnc. It first says "receiving data" but while doing so I get an error message saying "data recieved not in valid format, deleting data".
    I am using a 9 pin to 9 pin connection using a wire consulting the user manual of the machine.
    Can anyone please help me with this ?
    Aug 2007
    12
    Sounds as if you are loading NC program to the Conversation Editor.
    To correct go to Auxiliary mode select Change Editor, the select NC.
    The machine will have HURCO Basic NC and May have ISNC (Industry Standard NC or FANUC ).
    then try resending the file
  1. Hurco Ultimax II
    By gregm1976 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-23-2011, 08:11 AM
  2. Ultimax 3 Ver. 1.64
    By racer6645 in forum HURCO
    Last Post: 03-29-2008, 05:41 PM
  3. Hurco KM3 w/ Ultimax
    By Mr. LocoMartin in forum HURCO
    Last Post: 01-14-2008, 03:18 PM
  4. What to use as CAM for Ultimax 32?
    By bgmnn in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-20-2007, 08:03 PM
