587,434 active members*
3,270 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal VMC 15 won't power up after power outage
Results 1 to 11 of 11
    May 2015
    My Fadal was sitting powered on over night when we had a power blink. I returned to the shop and the machine was on. Tried powering up the CNC by hitting green button and now a humming noise is coming from right side control panel and won't power up.
    180
    Re: Fadal VMC 15 won't power up after power outage
    Have you checked all your circuit breakers? There are a couple in the side cabinet and a couple in the back cabinet.
    May 2015
    Yes I did. Just a humming noise in the side cabinet where the amplifiers are located but nothing is lit up.
    180
    I assume it's a 3 phase machine. Check the fuses on the main line. There should be 3 of them.
    May 2015
    Quote Originally Posted by ddgman2001 View Post
    Fuses were fine
    Feb 2008
    86
    Is the power supply energized? I believe the machine needs to see the proper conditions emerging from the power supply to power up the boards and ultimately the drives.
    Sep 2015
    25
    any resolution to this? having a similar issue after the machine sat with power off for a month, no issues prior to this. The only noticeable difference is that i am not hearing the relay click when the green button is pressed.
    Mar 2008
    683
    Make sure all 3 legs have power from the power company. Twice last week my shop complex lost one leg.
    Check K1 and K2 relays on the 1100-1 power distribution board, I had the same problem and it ended up being K1. to test it I took the Grayhill ELE-0070 for the beacon relay in the pendant since i didn't have any spares. fired right up. I have spares now haha.
    Jun 2011
    6
    Quote Originally Posted by jbranting View Post
    Where is that ELE-0070 ?
    Jan 2015
    417
    If you open up the Pendant (front of machine) on the right hand side in the pendant is 1100-3 board the ele-0070 (the only one on the board) is plugged into the K1
  1. Power outage in middle of tool change.
    By STASHU in forum Fanuc
    Last Post: 02-15-2014, 05:11 PM
  2. Power outage zapped my control...
    By MauserBob in forum Fanuc
    Last Post: 06-27-2012, 12:29 PM
  3. power outage restart
    By riverracer in forum Haas Mills
    Last Post: 03-31-2011, 01:36 AM
  4. Power Outage ?
    By Phishaholic in forum Tormach Personal CNC Mill
    Last Post: 06-29-2009, 11:15 PM
  5. Power outage during machining
    By walter in forum DIY CNC Router Table Machines
    Last Post: 08-02-2005, 03:13 PM
