587,925 active members*
3,786 visitors online*
Results 1 to 10 of 10
    RhinoCam Help
    Hello All,
    I was wondering since you toolpath off of regions, how do you toolpath a chamfer or a fillet?
    Bill
    Bill
    Hmmmmm,
    49 looks and no reply's? Come on folks, someone can surly answer this.
    Bill
    Bill
    Aug 2007
    215
    Hi - not exactly sure what you mean but I'll give it a go...
    RC uses regions for 2.5D and the model and stock for 3D. Any good?
    Nov 2004
    436
    Well, When I chamfer my stuff, I use a chamfering endmill, and use a curve that is the basic outline of the shape I am making. I select the Engraving, On Condition, and set the height parameters in there.
    For a fillet, you could do the same thing, if you have a tool of the appropriate shape. Once you discover the appropriate offset, (0.1875"? for a 1/4" shank router bit), you could offset your outline curve, and then engrave on condition to that. I would remove the follower bearing if it has one.
    Without that tool, you would half to do a parallel or horizontal finishing routine, with a ball endmill, and it will take a while.
    Rob
    Hi stirling,
    Yes ... I was wondering how to machine chamfer or radius on top of a part without having to machine the whole top surface, for instance like if I wanted to machine just the outer edge or just knock the sharp corner off or a leadin on a whole with out having to do the 3D cuts that go over the whole thing.
    Bill
    Bill
    Jan 2004
    3154
    Use a chamfer/radius cutter and a 2.5d profiling operation. Set the tool size as the tip diameter and use a cut depth equal to the top of the radial runout.
    You could also use an engraving path but the lead-in and out isn't as well suited.
    www.integratedmechanical.ca
    Sep 2006
    340
    Exclamation
    Simple... Make 2 boundries? Make one for the top or inside and one for the chamfer or outside.
    You can also set the TOP of the cut in the machining menus where it says TOP and Bottom... Make the top SLGHTLY below the top and Off you go...
    Lead ins can be changed to suit your work..
    Also HILL machineing may be a better approach..
    There are many many ways to do this without a specfic TOOL.. I use only ball nose and have no problems getting the paths I want...
    If this didn't help check the mecsoft forum, there are plenty of peeps who can help you with this...
    Good luck..
    Marc
    Hey check out my website...www.cravenoriginal.com
    Thanks Marc
    Jan 2004
    3154
    I agree
    Pointclouds approaches are perfect methods to do what you want using 3D machining strategies.
    Potentially (depending on stepover), you could do 5, 10, 20? times around to "single point" profile this type of edge.
    My method (although you have to buy a "special" tool) requires once around plus lead in/out.
    There is always more than one way to skin a cat.
    Aug 2007
    215
    would that be a 2.5D cat or a 3D cat?
    Sep 2006
    340
    all cats...
    Thanks Marc
  1. RhinoCAM Help ... It's Gone!
    By Micro Rotors in forum Rhino 3D
    Last Post: 08-29-2007, 05:42 PM
  2. RhinoCAM PRO
    By CAM USER in forum News Announcements
    Last Post: 09-07-2005, 10:05 PM
  3. RhinoCam
    By CarveJunky in forum Rhino 3D
    Last Post: 06-19-2005, 02:27 PM
  4. RhinoCam
    By Dogsione in forum Visual Mill
    Last Post: 01-26-2005, 06:09 AM
