I recently bought a "ZX45" (RF-45 Clone) from Wholesale Tools. I managed to get the thing off my truck and onto my garage floor, but now I'm looking to disassemble as much of it as I can (without messing anything up!) in order to get it into my basement. The head removal seems pretty straightforward, but I'm not sure about removing the longitudinal (x-axis) table.
I removed the roll pin and micrometer knob, as well as the two machine screws that secure the leadscrew bracket. What I'm not sure about though, are the the two pins (steel dowels) that remain inserted in the bracket. I gave a couple taps with a hammer on the back of the bracket, but it's not budging. When I looked at Grizzly manual for their version of the RF45 (G0519), it calls those pins "taper pins." If they truly are tapered pins, then I assume that they must be removed in order to get the bracket off? (Looks like there are internal threads--do I thread a machine screw in there to remove the pins?)
I'll try to attach a picture of the bracket and pins (will be my first try at attaching a photo so hopefully will do it right).
Thanks in advance for any help. This is a great forum.
