587,683 active members*
3,200 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Question about text editing after posting
    Jun 2015
    25
    Post Question about text editing after posting
    I am looking for a way to "replace all" text with ascending numbers to help with some editing after posting. I am aware that gibbs has an option to number all of the lines built in, but I find that the way it outputs the numbering is entirely too cluttered. I don't want each line numbered, I only want the operations numbered. Unless I'm missing out on a way to only number operations in ascending number?
    For example:
    I am trying to find all lines that start with the letter "N" and replace them with N1, N2, N3... so on and so forth.
    Currently I am using the "Replace All" option in notepad to simply replace comments with certain codes that I need for the machine I am running. It's sort of a posting issue work-around that I'm working with.
    Can anyone point me in the right direction as this would cut A LOT of time out of my programming.
    Jun 2015
    8
    Re: Question about text editing after posting
    If you select "minimize sequencing" on the post dialog box, it should only put an N number on each tool change.
    This depends on the post you are using, of course. But most posts I've seen do this.
    Alternatively, you can have someone create / modify a post for you so it only outputs N numbers on each new operation. It wouldn't be difficult to do.
    - - - Updated - - -
    Alternatively, you can use Notepad++ (it's a free program) which allows regex search and replace.
    Jun 2015
    25
    I got our post editor to add N"x's" after each operation so now it's numbering properly, but I'm still looking for a free editor that allows me to search for specific strings and copy the entire line (without adding line numbers before them).
    I am currently using a program called "Ultra Edit" but my license is about to expire. For example I am searching for all lines with G0G90 and I want to be able to copy the entire line after that. This is to help with a pre-piercing section of a program for laser cutting.
  1. Replies: 8
    Last Post: 07-26-2013, 01:24 AM
  2. editing drafting text vin x4
    By beekeeper in forum Mastercam
    Last Post: 11-06-2010, 07:48 AM
  3. editing in-line text using s-post
    By npparikh in forum Surfcam
    Last Post: 01-28-2010, 03:58 AM
  4. Editing question
    By cncadmin in forum OneCNC
    Last Post: 10-23-2004, 05:09 AM
