586,612 active members*
3,584 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > redsail chinese laser shuts down after binding during operation
Results 1 to 11 of 11
    Feb 2015
    5
    Newby with a x700 redsail ebay laser .I got everything running smoothly after solving a firing problem when the airhose and redlaser light wire gets caught on the frame of the machine binding and stopping progress.It made a unpleasant noise and shut down. I tried restarting the laser but the control panel will not light up again seems to have no power. the blower and air compressor still work connected to the back of the machine.I'm looking for a fuse or something i can replace and get it running but worry I fried the main control board. Can anyone help or have advice , Thanks
    Jan 2015
    17
    Re: redsail chinese laser shuts down after binding during operation
    I'm afraid i can't help you, however i wondered if you could tell me what software you're using?
    I have a redsail m500 and can't get it to work with the software i was given with it; usb driver doesn't work either.
    sorry i can't help, i'm totally clueless.
    Calida
    Feb 2015
    5
    Quote Originally Posted by Calida View Post
    Calida
    I'm using lasermate 5.2.05. I had the same problem with my usb the not working. or connecting to my computer.the driver should be on the disk with the software. I was installing it wrong. I went into the PC add new hardware and finally got it to work, after that your software should work
    Feb 2015
    5
    soon
    Quote Originally Posted by murfsrf View Post
    I found my problem. The laser was firing but when the arms were jarred and binding it knocked the mirrors out of alignment. laser was not even hitting the lens. Big relief. I made some other rookie mistakes i'll not talk about now. I'm sure i'll be here again with something new soon.
    Nov 2014
    284
    soon
    Would those mistakes include burn marks on your arms? :=)
    Jan 2015
    17
    Hi murf..... Was the driver a distinct file or part of the instalation? The software I've been sent doesn't have a distinct driver file but does say install usb, however it still doesn't load. I've tried going down the install hardware option but the computer doesn't recognise a driver to install. What's your driver file called? Is it in c/system 32/drivers?
    For driver questions, what about computer system xp or win 7 32 or 64 bits? Had you try to install again for USB driver.
    It will be better if you can send one short video for check the problem. You can email us [email protected]
    Web.:http://www.jncslaser.com/ Email: [email protected] Whatspp: +86-18254116182
    Facebook: https://www.facebook.com/jncslaser Skype: consurelaser
    Jan 2015
    17
    Did you get my email? Thanks x
    Feb 2015
    5
    Sorry i cant be help you more with this problem. I used recommended xp /32 computer then connected PC to laser with a search for new hardware a window opened a driver number and question mark next to it. I did the option to search the internet for the driver. I ended up down loading a driver then add new hardware and somehow got it right. Wish I could tell the exact driver that was used and if i can find in my downloads i will re-post.
    Jan 2015
    17
    Thanks all good info
    Jan 2015
    17
    Finally got it talking.....now to master the settings and how to work the software. Using LaserCutEngrave 3. Anyone familiar???
  1. pega shuts down in auto operation
    By russell7890 in forum Fanuc
    Last Post: 12-30-2014, 02:32 AM
  2. Redsail x700 laser
    By williamkelty in forum Redsail Laser
    Last Post: 10-23-2014, 06:03 AM
  3. Redsail Laser Help...
    By ivirscar in forum Redsail Laser
    Last Post: 11-25-2011, 09:31 AM
  4. redsail laser RS6090C
    By VJK in forum Redsail Laser
    Last Post: 06-04-2011, 06:38 AM
  5. Redsail Laser printing help...
    By ivirscar in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-25-2007, 04:03 AM
