587,822 active members*
2,920 visitors online*
Thread: 2D POCKETING
    Sep 2007
    92
    2D POCKETING
    I am using X3 and would love to know how to make my endmill enter a pocket a specific location where there is already a thru hole so that I do not have to ramp or plunge into solid, thanks in advance
    Aug 2009
    106
    Chain the point where your thru hole is first.
    Chain your Contour like you usually do.
    Under Lead In / Lead Out check the box that says Use Entry Point. If you want your endmill to exit at the same point check the box that says Use Exit Point.
    Feb 2008
    51
    I am using x4 what I did was created a point at the hole location and used helix as an entry and check the box with center on entry point and it started at the point
    Sep 2007
    92
    thanks for the quick reply, I will try it now
  1. Need help with pocketing!
    By wdp67 in forum BobCad-Cam
    Last Post: 01-18-2008, 10:41 PM
  2. help with pocketing on MCX
    By genexis in forum Mastercam
    Last Post: 06-29-2007, 04:35 PM
  3. Pocketing in V9 help
    By Joe Rodney in forum Mastercam
    Last Post: 02-26-2007, 06:57 PM
  4. Pocketing
    By cncadmin in forum Uncategorised CAM Discussion
    Last Post: 05-12-2006, 02:44 AM
  5. Pocketing
    By Mortek in forum OneCNC
    Last Post: 04-08-2003, 10:08 PM
