I've got a Sieg X2 mill that I want to convert to CNC.
I've ordered the CNC Fusion #2 kit - with ballscrews for the X,Y and Z axis.
For motors, I'm thinking of using three NEMA23 3.1Nm steppers (439oz).
To control these, I would rather use an individual driver for each motor as well as an individual breakout board, rather than a combined one (such as a Gecko G540).
I like modular designs. I've found a pretty cheap driver - rated at 50v and 4.5A, supporting microstepping:
Stepper Motor Driver 4.5A, 50V CNC Microstepping
The same hardware is available under several names, including Rhonmac-CNC (their page includes internal photos):Stepper Motor Drivers
Specs:
High torque at high speed at a low cost
Voltage from +20Vdc to +50Vdc. Current output up to 4.5 amps adjustable onboard with dip switches
Automatic idle-current reduction, reducing motor heating
3-state current control also reducing motor heating
14 Selectable resolutions from 400 to 25000 pulses/rev. DIP switch selectable
Suitable for 4, 6 and 8 lead motors. 2 phase and 4 phase motors
DIP switch current setting with 8 settings
Short circuit, over voltage, low voltage protection
Easy wiring by screw terminals
Size 107 x 33 x 85mm. With built in heat sink.
Can be Mounted Vertically or Horizontally
High performance microstepping chopper Driver with small size therefore small enclosure footprint is achievable. Advanced protection circuit built in as standard please see data sheet below.
All inputs are optically isolated giving further protection in isolating driver from control electronics and helps with noise immunity.
I've found this driver on ebay for £110 for three drivers and a seperate breakout board. This seems quite cheap for three 4.5A 50v drivers.
I'm planning to run everything off 48v.
Any thoughts or advice on my setup? The only part ordered so far is the CNC Fusion kit. Are three NEMA23 439oz motors a good choice for this?
Many thanks
Andrew
